[mapguide-users] OGR and PostgreSQL...can't see data in table
Frank Warmerdam
warmerdam at pobox.com
Tue Feb 5 14:40:19 EST 2008
Maciej Skorczewski wrote:
> ok i see it in faq
> i try use query like this...
> ogrinfo -ro PG:dbname=warmerda -sql "SELECT pop_1994 from canada where
> province_name = 'Alberta'"
Maciej,
Note, if you access a table that way, you are avoiding the normal
feature table access. Instead of using the -sql option, you should
specify the table/layer name as an argument. This would be the closest
analog to what FDO and mapguide will do.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
