[mapguide-users] Add Point to Existing Layer
gaku
hamazato at yachiyo-eng.co.jp
Wed Feb 6 05:35:33 EST 2008
Thanks you.
I went to http://localhost/mapguide/mapagent/index.html
I went to GetResourceContent Link, and perform a query using the ResourceID
like Library://Mysite/Data/test.FeatureSource
I got an XML file like this.
<Provider>OSGeo.SDF</Provider>
<Parameter>
<Name>File</Name>
<Value>%MG_DATA_FILE_PATH%test.sdf</Value>
</Parameter>
<Parameter>
<Name>ReadOnly</Name>
<Value>False</Value>
</Parameter>
Pascal Coulon wrote:
> Hi There,
> When creating a layer (SDF) in Studio. It is created in ReadOnly mode. You
> need to enable read/write by using the mapagent. Let me know if you need
> any further details.
> Regards,
> pascal
> Jackie Ng wrote:
>> Open two browser windows/tabs, one to your web application that adds the
>> points. Another to the schemareport page (usually at
>> http://servername:port/mapguide/schemareport/main.php )
>> Run your add point routine, then check if the schemareport for that
>> feature source has included the point you have just added.
>> If the point is there, then i suspect it is something to do with the
>> layer that's based off of the feature source.
>> Otherwise, your php script is clearly failing to insert the new point
>> feature.
>> - Jackie
>> gaku wrote:
>>> Yes,I have created site resources by use Administrator username.
>>> -gaku
>>> Jackie Ng wrote:
>>>> Oh I see, I thought you were adding points to a session-based feature
>>>> source.
>>>> In that case, did you create a mapguide session via a username that has
>>>> permissions to modify site resources?
>>>> - Jackie
>>>> gaku wrote:
>>>>> Yes, I have created the feature source by using Mapguide Studio.
>>>>> Jackie Ng wrote:
>>>>>> Have you actually created the feature source pointed to by
>>>>>> $featureSourceId ? (ie. Have you called
>>>>>> $featureService->CreateFeatureSource() ?)
>>>>>> - Jackie
>>>>>> gaku wrote:
>>>>>>> Hi all
>>>>>>> I'm trying to let the user insert a point feature in PHP along with
>>>>>>> some attributes. The feature source is an SDF file and the code was
>>>>>>> translated/modified from the PHP example (draw_line). The user can
>>>>>>> get the X, Y coordinates from another button (works fine).
>>>>>>> Everything compiles fine and execute well but no feature is added to
>>>>>>> the feature source. I tried with a converted SDF feature source
>>>>>>> (didnt change a thing).
>>>>>>> Did I miss something ? Did I do something wrong :)
>>>>>>> Any help would be appreciated
>>>>>>> here's the code :
>>>>>>> try
>>>>>>> MgInitializeWebTier($webconfigFilePath);
>>>>>>> // Get the session information passed from the viewer.
>>>>>>> $sessionId = ($_SERVER['REQUEST_METHOD'] ==
>>>>>>> "POST")?$_POST['SESSION']: $_GET['SESSION'];
>>>>>>> // Get the user information using the session id,
>>>>>>> // and set up a connection to the site server.
>>>>>>> $userInfo = new MgUserInformation($sessionId);
>>>>>>> $siteConnection = new MgSiteConnection();
>>>>>>> $siteConnection->Open($userInfo);
>>>>>>> $resourceService =
>>>>>>> $siteConnection->CreateService(MgServiceType::ResourceService);
>>>>>>> $featureService =
>>>>>>> $siteConnection->CreateService(MgServiceType::FeatureService);
>>>>>>> $featureSourceId = new
>>>>>>> MgResourceIdentifier('Library://Sample/Data/020101Markup.FeatureSource');
>>>>>>> $map = new MgMap();
>>>>>>> $map->Open($resourceService, $mgMapName);
>>>>>>> //$geometryFactory = new MgGeometryFactory();
>>>>>>> $wktReaderWriter = new MgWktReaderWriter();
>>>>>>> $agfReaderWriter = new MgAgfReaderWriter();
>>>>>>> $geo = $wktReaderWrite->Read("POINT XY ( $x, $y )");
>>>>>>> $geoByteReader = new MgByteReader();
>>>>>>> $geoByteReader = $agfReaderWriter->Write($geo);
>>>>>>> $idid = 500;
>>>>>>> $propertyValues = new MgPropertyCollection();
>>>>>>> $propertyValues->Add(new MgInt32Property("ID", $idid ));
>>>>>>> $propertyValues->Add(new MgStringProperty(name, 'test'));
>>>>>>> $propertyValues->Add(new MgGeometryProperty('Geometry',
>>>>>>> $geoByteReader));
>>>>>>> $commands = new MgFeatureCommandCollection();
>>>>>>> $commands->Add(new MgInsertFeatures('020101Markup',
>>>>>>> $propertyValues));
>>>>>>> $featureService->UpdateFeatures($featureSourceId, $commands,
>>>>>>> false);
>>>>>>> catch (MgException $e)
>>>>>>> $errorMsg = $e->GetMessage();
>>>>>>> $errorDetail = $e->GetDetails();
>>>>>>> -------------------------------end of code -------------
>>>>>>> --Thanks,
View this message in context: http://www.nabble.com/Add-Point-to-Existing-Layer-tp15136337s16610p15306461.html
