[mapguide-users] ApacheMapguide and mysql
Jason Birch
Jason.Birch at nanaimo.ca
Fri Feb 8 01:23:38 EST 2008
You may be running into an error in your PHP code (like, maybe the MySQL extension isn't enabled in the MapGuide build) but not seeing the error because error reporting is turned off in MapGuide's php.ini file.
Jason
Subject: [mapguide-users] ApacheMapguide and mysql
But when I browse the file
"http://localhost:8700/mapguide2008/mysql_connect.php", I got white blank
page..If mysql_connect.php failed, it's supposed to give me an error...
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080207/e3d09244/attachment.bin
