[mapguide-users] RC2 fusion samples question (simple sample)
Paul Spencer
pagameba at gmail.com
Mon Feb 11 19:23:52 EST 2008
No docs available yet, but I believe some are coming. It probably
won't be a lot for this release, though.
Paul
On 8-Feb-08, at 9:09 PM, Zac Spitzer wrote:
> are there any dev guides / doco anywhere for fusion ?
> On Feb 9, 2008 1:05 AM, Mike Adair <madair at dmsolutions.ca> wrote:
> Zac,
> The MapGuide simple sample in Fusion hasn't yet been converted from an
> older version of the code. This has been fixed and will be
> available in
> the next RC.
> For the gmapTiled map definition, I'll have to confirm but we should
> be
> able to make a package for that available.
> Mike
> Zac Spitzer wrote:
> > I have successfully installed the rc2 side by side with my existing
> > 1.20 installation.
> > On looking at fusion, the simple sample refers to
> > Library://Samples/Gmap/Maps/gmapTiled.MapDefinition
> > which I don't have ( i have just installed the Sheboygan sample)
> > Is this available? I tried to edit the WebLayout.xml in that
> directory
> > to point to the Sheboygan map definition but
> > that doesn't seem to work, and i can't see it being loaded using
> > livehttpheaders
> > I am also seeing fusion generating a 404
> > [Fri Feb 08 17:42:45 2008] [error] [client 192.168.1.3
> > <http://192.168.1.3>] File does not exist: C:/Program
> > Files/MapGuideOpenSource2.0/WebServerExtensions/www/fusion/samples/
> mapguide/simple/ApplicationDefinition.xml,
> > referer: http://zac:8018/mapguide/fusion/samples/mapguide/simple/
> > z
> > Zac Spitzer -
> > http://zacster.blogspot.com (My Blog)
> > +61 405 847 168
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> +61 405 847 168 _______________________________________________
