[mapguide-users] Fusion and google earth widget
Paul Spencer pagameba at gmail.com
Tue Feb 12 15:16:29 EST 2008
Opps, I think I mis-understood your original email.  I thought you
were asking if you could display mapguide stuff on top of Google Maps
inside a Fusion application, but re-reading it I see that you want to
export the data from the current map as a KML feed that can be opened
in Google Earth.  Since MapGuide supports output as KML I would expect
it to be pretty easy to add a 'download as KML' type widget but again
it is not actually done yet.
Cheers
Paul
On 12-Feb-08, at 10:03 AM, BradM wrote:
> Paul, your plan is welcome news.  What is your time line for
> supporting the
> OpenLayers layer types and is there any way that I could help
> expedite the
> building of these tools / widgets?  thanks
> Paul Spencer-5 wrote:
>> Brad,
>> Unfortunately not.  It is possible to do it using custom javascript
>> and some poking around in the code.  My intention is to support all
>> the OpenLayers layer types through the ApplicationDefinition so you
>> could specify a Google layer in the ApplicationDefinition (or any
>> other 'external' data source for that matter).
>> Cheers
>> Paul
>> On 6-Feb-08, at 1:40 PM, BradM wrote:
>>> Has anyone made a simple plug and play widget / tool for Fusion so
>>> users can
>>> easily view map layers on google earth?
>>> thanks
>>> View this message in context:
>>> http://www.nabble.com/Fusion-and-google-earth-widget-tp15306956s16610p15306956.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/Fusion-and-google-earth-widget-tp15306956s16610p15434263.html
