[mapguide-users] Feature Joins absolutely broken in MGOS 2.0.0 RC1
Bruce Dechant bruce.dechant at autodesk.com
Wed Feb 13 02:44:31 EST 2008
Jackie,
Can you provide additional information as the issue with ticket 429 was easy for me to reproduce and then fix?
What OS you are running? Apache or IIS web tier?
Did you update both server and web tier?
Does this same issue happen on a completely new server install with a fresh unused repository?
Perhaps it is related to the migration of your repository as I verified this defect with a brand new install of RC2.
Can you send me your feature source and layer definition XML files so that I can examine them?
Thanks,
Bruce
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, February 12, 2008 11:56 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Feature Joins absolutely broken in MGOS 2.0.0 RC1
3rd time does not seem to be the charm :(
RC3 still fails to render my test joined layers correctly (re: ticket 429)
or at all :(
- Jackie
Bruce Dechant wrote:
> This issue was also in RC2.
> I have tracked down the issue and fixed it.
> See trac ticket http://trac.osgeo.org/mapguide/ticket/429
> Thanks,
> Bruce
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
> Sent: Monday, February 11, 2008 2:24 PM
> To: MapGuide Users Mail List
> 2.0.0 RC1
> There is a known issue with feature joins in RC1.
> It is being looked at.
> Thanks,
> Bruce
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jon Rizzo
> Sent: Monday, February 11, 2008 9:58 AM
> Subject: Re: [mapguide-users] Feature Joins absolutely broken in MGOS
> 2.0.0 RC1
> Restarting the server doesn't seem to help for me.  I agree w/you: I hope
> this is resolved in the final version - joins are critical to my sites and
> I
> can't upgrade if it breaks my existing sites.
> http://www.nabble.com/Feature-Joins-absolutely-broken-in-MGOS-2.0.0-RC1-tp15152062s16610p15414807.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Feature-Joins-absolutely-broken-in-MGOS-2.0.0-RC1-tp15152062s16610p15450571.html
