[mapguide-users] Postgis Selection Problem (additional)
Jason Birch
Jason.Birch at nanaimo.ca
Wed Feb 13 14:53:07 EST 2008
I'd be interested in knowing if this problem persists when you change
your rendering engine from AGG to GD.
To test this, you can modify this setting in the serverconfig.ini file
under c:\program files\mapguideopensource2.0\server\bin and then restart
the MapGuide Server service.
Jason
Subject: [mapguide-users] Postgis Selection Problem (additional)
It works for simple polygon consists of 4 corner but doesn't work for
complex polygon consists of thousand points..
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080213/2624a0c8/attachment.html
