[mapguide-users] how to load shp file in opensource
swetha1 swetha.sub at gmail.com
Thu Feb 14 05:48:23 EST 2008
Hello Dorin
Thanks a lot i tried it out with the 60 day trial version, and was able to
do it. Now the problem which has arised is the shp files which i have the
projection system as WGS84. And Even if i am trying to set it as LatLog it
is not displaying the map.
Anyways thanks for your help!
Regards
Swetha
Dorin333 wrote:
> Hello!
> You need to install Autodesk Mapguide Studio (
> http://usa.autodesk.com/adsk/servlet/index?id=7176611&siteID=123112  with
> Get a free trial -60 days availability).
> With this application you can import different type of map file, including
> SHP.
> Bets regards,
> Dorin Iordache
> ----- Original Message ----
> From: swetha1 <swetha.sub at gmail.com>
> To: mapguide-users at lists.osgeo.org
> Sent: Thursday, February 14, 2008 8:56:09 AM
> Subject: [mapguide-users] how to load shp file in opensource
> Hi!
> I am currently working with mapguide open source 1.2.0. Now in this we
> have
> inbuilt studio available from where we need to load the shp file right?
> But
> my problem is i am unable to create even a folder in that WebStudio....
> How
> do i proceed? do i have to convert this .shp file to .mgp? If yes then how
> do i convert it? Please help me out in this.
> Thank!
> Swetha
> http://www.nabble.com/how-to-load-shp-file-in-opensource-tp15475037s16610p15475037.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> ____________________________________________________________________________________
> Never miss a thing.  Make Yahoo your home page.
> http://www.yahoo.com/r/hs
View this message in context: http://www.nabble.com/how-to-load-shp-file-in-opensource-tp15475037s16610p15477895.html
