[mapguide-users] error in weblayout preview
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Feb 14 07:49:45 EST 2008
Since MapGuide Studio is an Autodesk product, you should consult
Autodesk when you have trouble with it.
You are seeing the folders, because Studio is using the WebServer to
produce the previews, and rely on a default document setting.
You can try re-installing MapGuide, or set the folder
"http://localhost/mapguide/mapviewerajax" to point to the
www/mapviewerphp folder and set the default document to be ajaxviewer.php.
Regards, Kenneth, GEOGRAF A/S
Vishaal skrev:
> Hi,
> i am facing a strange problem in weblayout of Autodesk Mapguide Studio 2007.
> i have created a weblayout and when i try to preview the same i get a list
> of directories available in the mapguide open source.
> also if i try to edit certain commands or change the order of certain
> command in the web layout editor in Autodesk MapGuide Studio 2007, then my
> solution comes to a halt and nohing is displayed esle than an Mgexception.
> any help would be highly appreciated.
> thanks in advance.
