[mapguide-users] MGOS 2.0 patch for MG Studio 2008 problem
Francisco J Rojas D francisco.rojas at dasoft.com.mx
Fri Feb 15 12:57:01 EST 2008
Hi:
The Problem is that you have installed a PREVIEW version of MapGuide Studio
2008, prior to 1.2.0.4103.
I have already double check and If I patch the preview version of MapGuide
Studio 2008 v 1.2.0.31xx, I have the same issue as you, but if I patch the
final commercial version, v 1.2.0.4103, the patch works fine.
Francisco Javier Rojas Duran.
zspitzer wrote:
> I get the following error after installing the patch after which i can't
> do
> anything :(
> Method not found: 'Boolean
> Autodesk.Studio.Site.SiteManager.IsAuthenticated(
> system.string, system.string)
> z
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MGOS-2.0-patch-for-MG-Studio-2008-problem-tp15368365s16610p15505766.html
