[mapguide-users] Question on MapStudio OS (for Kenneth)
Maksim Sestic
max at geoinova.com
Sat Feb 16 06:30:19 EST 2008
Kenneth, thanks a lot for the clarification. Do you, by any chance, keep a
list of unmanaged libraries used by MapGuideNativeAPI.dll in case it uses
native MGOS connection object to connect to the server (DllImport-ed ones)?
I'm just trying to keep the list short as much as possible :-)
If certain MG-based FDO operations are not currently supported on
HttpServerConnection level, I guess I'll have to get around MG and talk to
managed FDO libraries directly, but this is a lesser problem.
IMHO, MG community is currently aware of MapStudio OS as a counterpart of
MapGuide Studio, but this managed layer underneath (MapGuideAPI.dll) is even
more interesting. Both MGOS and MGE do lack usable managed layer, I hope
someone (you?) will introduce a motion/RFC to adopt it as a standard
supplement to both.
Regards,
Maksim Sestic
Kenneth, GEOGRAF A/S wrote:
> The code for the MapGuideNativeAPI.dll is present in the sourcecode for
> MapStudioOS (look in MapGuideAPI/NativeAPIWrapper).
> This code is generated with the MapGuide Open Source SWiG build, but I
> removed all .Net 2.0 stuff, and replaced it with .Net 1.1 counterparts.
> Recently I have modified the generated code a bit, so that it will run
> on both 1.2 MapGuide dll's and 2.0 dll's.
> The MapGuideNativeAPI.dll is almost the same as the one distributed as
> MapGuideDotNetApi.dll (with the diffs mentioned above).
> If you wish to use some of the more "advanced" stuff, where you can
> modify classes instead of Xml, you have to reference the MapGuideAPI.dll.
> This DLL offers two connections to the MapGuide Server, namely
> HttpServerConnection and LocalNativeConnection.
> The first one is 100% managed and does not use/need the Binaries shipped
> with MapGuide.
> The second one uses the MapGuideNativeAPI.dll to access the MapGuide
> binaries (dll files), and connects with those.
> Both types of connection offers an identical set of methods to
> read/write MapGuide data as classes, rather than Xml.
> Unfortunately the Http interface does not support all the features of
> the NativeAPI, so some features are only accessible
> by calling that directly (missing methods are mainly related to FDO
> create/update).
> You can mix and match as you like, I see no problems in using both API
> models at the same time.
> I have tested the code with both MGOS and MGE, I even have special code
> to handle MGE 2007 runtime maps :).
> FYI, the HttpServerConnection is more extensively tested than the
> Regards, Kenneth, GEOGRAF A/S
View this message in context: http://www.nabble.com/Question-on-MapStudio-OS-%28for-Kenneth%29-tp15499972s16610p15517230.html
