[mapguide-users] Local drive vs Network drive with MGOS (Vista/XP)
Pierre Cardinal pierre.cardinal at sympatico.ca
Tue Feb 19 19:46:43 EST 2008
I finally make it works by using the command  "net use ..." under the system
account of my virtual machine.
Thanks for your support
Pierrre
Andy Morsell wrote:
> In Windows Explorer on your virtual machine, can you login and
> successfully
> connect to the network locations in question?  If so, then the problem is
> that the MapGuide Windows Service itself does not have necessary rights to
> that location and is most likely running under a local system account (by
> default) that does not have the necessary network privileges to that
> location.  Go into Windows Services, find your MapGuide Open Source
> service,
> go to it's properties, then to the Log On tab and change the account that
> it
> runs under as one that has the correct privileges to those network
> locations.
> If this is not your problem and you cannot connect to network locations
> outside of your VMWare instance under any circumstances, then you may have
> a
> problem with your VMWare network adapter.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Pierre
> Cardinal
> Sent: Tuesday, February 19, 2008 3:04 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Local drive vs Network drive with MGOS
> (Vista/XP)
> Thank you both for your help but I still have the problem. Could it be
> VMware? My OS are running in VMware with MGOS and I am trying to connect
> with drive that are outside VMware (network drive).
> Pierre
> Pierre Cardinal wrote:
>> Environment: XP or Vista with MG studio and MGOS 2.0 RC3.0
>> It is possible with MG Studio to connect with data stored on local
>> drives but not with data stored on network drives. What should I do to
>> use an alias with a network drive? The problem is the same with ODBC
>> (unable to connect with data stored on network drives).
>> Pierre
> http://www.nabble.com/Local-drive-vs-Network-drive-with-MGOS-%28Vista-XP%29-
> tp15518597s16610p15578351.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Local-drive-vs-Network-drive-with-MGOS-%28Vista-XP%29-tp15518597s16610p15579889.html
