[mapguide-users] MG 2.0 RC4 selection ALMOST working
ary sucaya ary.sucaya at yahoo.com
Wed Feb 20 02:55:32 EST 2008
Still doesn't work for me with the same problem as before and even worst. I couldn't made selection for all object. Prior to RC4, i could select object consists of 4 corner. Now i can't select anything.. Selection tool doesn't render selected object but shows object properties, number of object selected (in statusbar)
Another problem of this release is my page cannot be displayed often. It complain about there are too many people accessing the web site..
Kind regards,
Ary Sucaya
----- Original Message ----
To: mapguide-users at lists.osgeo.org
Sent: Tuesday, February 19, 2008 9:15:35 PM
Subject: [mapguide-users] MG 2.0 RC4 selection ALMOST working
I was previously having issues with selection (http://www.nabble.com/Postgis-Selection-Problem-%28additional%29-tt15466067s16610.html) where it looked like my objects were selected, but nothing actually was, and RC4 has made great strides to remedy this. However, my current situation is this:
I can use the selection tool to make selections on the map. But, they don't show up unless I click the 'Refresh Map' button. And even then, the statusbar still shows No features selected. But when I run our script, the output is correct and formatted accordingly. Yet, If I make a selection programmatically like stated in the linked post, the selection is highlighted, and the statusbar reads {0} features selected on {1} layers, yet shows that two layers are selected in the selection panel, wells and blocks. And, no matter which block I select--even if the block has nothing inside--the selection panel always shows the same two wells selected. Also, if I make a selection with the tool, I cannot use the 'Clear Selection' tool, but it is available when objects are selected programmatically.
I don't know what is causing this behavior, but these are my observations so far. If I come across anything new, I will update here. At least the selections are working enough to use and test our scripts, and for that, I am glad.
View this message in context: MG 2.0 RC4 selection ALMOST working
-----Inline Attachment Follows-----
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080219/951af726/attachment.html
