[mapguide-users] MG 2.0 RC4 selection ALMOST working
Jason Birch Jason.Birch at nanaimo.ca
Thu Feb 21 11:32:54 EST 2008
Is that just for PostGIS, or is it happening for other feature providers too?
Currently Tom has moved that RC4 be tagged as release, so if this is something that is not specific to the PostGIS provider and it is critical, you should make sure to create a ticket in Trac with enough information (data, MGP package, operating system, web server, which viewer you're using) to replicate the problem.
If it is PostGIS-specific, then it likely won't be fixed in MapGuide.  Bruno Scott is doing a bunch of work on the PostGIS provider currently, so hopfully it will be fixed through his efforts.
Jason
Subject: [mapguide-users] MG 2.0 RC4 selection ALMOST working
I was previously having issues with selection (http://www.nabble.com/Postgis-Selection-Problem-%28additional%29-tt15466067s16610.html) where it looked like my objects were selected, but nothing actually was, and RC4 has made great strides to remedy this. However, my current situation is this:
I can use the selection tool to make selections on the map. But, they don't show up unless I click the 'Refresh Map' button. And even then, the statusbar still shows No features selected. But when I run our script, the output is correct and formatted accordingly. Yet, If I make a selection programmatically like stated in the linked post, the selection is highlighted, and the statusbar reads {0} features selected on {1} layers, yet shows that two layers are selected in the selection panel, wells and blocks. And, no matter which block I select--even if the block has nothing inside--the selection panel always shows the same two wells selected. Also, if I make a selection with the tool, I cannot use the 'Clear Selection' tool, but it is available when objects are selected programmatically.
I don't know what is causing this behavior, but these are my observations so far. If I come across anything new, I will update here. At least the selections are working enough to use and test our scripts, and for that, I am glad.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080221/a21d1f5e/attachment.bin
