[mapguide-users] MGOS 2 RC4 Observations
Jackie Ng
jackie.ng at aecsystems.com.au
Fri Feb 22 00:52:47 EST 2008
My observations so far:
- Feature Joins are now working properly again (took 3 RCs to get there),
but performance has somewhat degraded as a result.
- There are lots of minor bugs/annoyances/usability problems with Fusion
and/or the 5 example templates. Case in point: the number of Fusion related
bugs I've filed on Trac.
My view as a result is to stay w/ 1.2 for a bit longer, and use 2.0 as a
testbed for new Fusion-driven designs, with full migration on the next 2.x
point release.
- Jackie
Andy Morsell wrote:
> Finally got around to testing RC4 a little and here are my observations.
> The test platform is a VMWare instance running Windows XP, using the .NET
> web extensions, and testing with IE and Firefox. Testing was difficult
> due
> to instability and crashing issues with Autodesk MapGuide Studio 2009
> beta,
> but I tried to make the best of it.
> - Tooltips do not work for any flexible layout with any layer source,
> including the Sheboygan samples. They work for normal layouts.
> - With flexible layouts, when using the selection tool, no attributes for
> the selected object (which always highlighted properly) were visible in
> the
> Selection Panel, although the layer and number of selected objects were
> properly displayed. This was the case for any layer source, including the
> Sheboygan samples. Selection attributes work fine in the properties pane
> in
> standard layouts still.
> Other than that, everything seemed to work okay in my informal testing and
> Fusion is beyond cool. I have not tried to migrate any custom 1.2 apps
> over
> yet, so cannot comment on that aspect at this time.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MGOS-2-RC4-Observations-tp15624277s16610p15628228.html
