[mapguide-users] change default selection icon
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Feb 22 06:51:49 EST 2008
I don't think you can change the cursors in the DWF viewer, so that
might be the problem.
Regards, Kenneth, GEOGRAF A/S
Rahul skrev:
> Hi,
> Thanks for your kind reply,Actually now i able to get going with the
> article at --
> http://www.nabble.com/Mouse-cursor-in-Ajax-viewer-to11030265s16610.html#a11068131
> Once i  changed the code in the toolbar.templ file ,and stored the
> *.cur files i able to perform the desired results but this alteration
> started causing problem in *_dwfviewer and it use to give alert about
> missing component in the toolbar.php_* which directed to the
> toolbar.templ.
> Thks
> Max
> ----- Original Message ----
> From: "Kenneth, GEOGRAF A/S" <ks at geograf.dk>
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Sent: Wednesday, February 20, 2008 11:50:25 PM
> Subject: Re: [mapguide-users] change default selection icon
> This has been discussed before, you should be able to find it in the
> archives, if no-one re-posts the info.
> If you do get the info, it would be nice if you would add it here:
> http://trac.osgeo.org/mapguide/wiki/CodeSamples
> Rahul skrev:
>> Hi All,
>>            How can i change the by default pointer icon to different
>> icons when we use to select different tool functions like when we pan
>> i want to show hand as compared to showing selection pointer
>> similarly for zooming and other features i want to change to more
>> relevant icon as compared default selection pointer icon.
>> I am using MGOS 1.2 ,can anybody suggest me how to proceed in this !!
>> Thks
>> Max !
>> Never miss a thing. Make Yahoo your homepage.
>> <http://us.rd.yahoo.com/evt=51438/*http://www.yahoo.com/r/hs>
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> -----Inline Attachment Follows-----
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080222/4d91c4ef/attachment.html
