[mapguide-users] MGOS 2 RC4 Observations
Zac Spitzer zac.spitzer at gmail.com
Tue Feb 26 21:34:10 EST 2008
here are my performance observataions using a largish map
1.2 GD takes 15s,
2.0 AGG takes 20s
2.0 GD takes 19s
All the feature sources are the same SDF files and there are no joins involved
On Sat, Feb 23, 2008 at 7:56 AM, shreepad <shreepadr at valuecad.com> wrote:
>  Good observations.
>  I have tested it with SDE 9.2 works really well much better than 1.2
>  migrated one test application
>  Works good speed is still a issue. did not work on fusion technology yet
>  with migrated app.
>  as its giving me all kinds of different results. May be for now I will stick
>  to normal layout and use fusion with later versions
>  Testing 2. With oracle works well. Tried king beta its works but have some
>  issues that I will send here pretty soon
>  Overall much better product
>  Shreepad Ranadive
>  ValueCAD
>  444 natoma st
>  Safrancisco ,CA 95555
>  415-516-8633
>  Andy Morsell wrote:
>  > Finally got around to testing RC4 a little and here are my observations.
>  > The test platform is a VMWare instance running Windows XP, using the .NET
>  > web extensions, and testing with IE and Firefox.  Testing was difficult
>  > due
>  > to instability and crashing issues with Autodesk MapGuide Studio 2009
>  > beta,
>  > but I tried to make the best of it.
>  > - Tooltips do not work for any flexible layout with any layer source,
>  > including the Sheboygan samples.  They work for normal layouts.
>  > - With flexible layouts, when using the selection tool, no attributes for
>  > the selected object (which always highlighted properly) were visible in
>  > the
>  > Selection Panel, although the layer and number of selected objects were
>  > properly displayed.  This was the case for any layer source, including the
>  > Sheboygan samples.  Selection attributes work fine in the properties pane
>  > in
>  > standard layouts still.
>  > Other than that, everything seemed to work okay in my informal testing and
>  > Fusion is beyond cool.  I have not tried to migrate any custom 1.2 apps
>  > over
>  > yet, so cannot comment on that aspect at this time.
>  > Andy Morsell, P.E.
>  > Spatial Integrators, Inc.
>  > http://www.SpatialGIS.com
>  > mapguide-users mailing list
>  > mapguide-users at lists.osgeo.org
>  > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>  View this message in context: http://www.nabble.com/MGOS-2-RC4-Observations-tp15624277s16610p15641641.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
