[mapguide-users] InitializeWebTier
swetha1
swetha.sub at gmail.com
Thu Feb 28 01:40:56 EST 2008
Well i am running the application with Visual Studio built in
WebServer.....How do i change the WebServer??? And Regarding the folder have
prepared it in the www folder.... So may be the webserver is creating the
problem.... Can you please send me the code and help me out in how to change
the WebServer.....I am new user to both Visual Studio and Mapguide
OpenSource..... And have a submission in 2 days.... Please
Thanks for your help in advance
Jackie Ng wrote:
> InitializeWebTier() is defined in the utilityfunctions.aspx that you
> omitted from inclusion.
> The reason you are getting errors in are probably because of:
> - You are using frames (evil, but unavoidable since that's how the AJAX
> viewer was designed). Visual Studio has no designer support for
> frames/framesets and can throw false errors, and most of the time these
> are non-fatal validation errors becuase you are validating a frameset
> document with a non-frameset doctype.
> - You are probably running your asp.net application with Visual Studio's
> built in webserver (Cassini), this will NOT WORK because it requires
> access to the mapviewernet and mapagent directories that Cassini does not
> and will not know about. You must configure your project to launch in IIS.
> - All the sample code is inline like classic asp, which goes against the
> common asp.net code-behind model, making it hard to "copy and paste" to
> your asp.net projects.
> - The dotnetviewersample was done with the expectation that it is to be
> deployed in the www folder of your MGOS installation (because it is
> hardcoded to look for webconfig.ini in that folder). If you have copied
> the dotnetviewersample, file-by-file, line-by-line it will probably fail
> if it is not inside the www folder.
> So my recommendation is:
> - Put your code in a folder inside MapGuide's www directory.
> - Put that include utilityfunctions.aspx line back in.
> - Ignore any non-compliation errors Visual Studio throws at you.
> Hope that helps.
> - Jackie
> swetha1 wrote:
>> Hi,
>> I am trying to open this dotnetviewersample in Visual studio, It is
>> giving an error in the utilityfunction.aspx....so i created my own
>> project where in i pasted the code from ajaxviewersample and deleted the
>> line #include file="utilityfunctions.aspx"......and tried calling the
>> weblayout in that file.... where it is giving the error in
>> initializewebtier().....cant understand what to do and how to proceed
>> with...
View this message in context: http://www.nabble.com/InitializeWebTier-tp15729918s16610p15730629.html
