[mapguide-users] 2.0 rc4 build failing on Ubuntu 7.10
Jo Cook j.cook at OXFORDARCH.CO.UK
Thu Feb 28 09:57:48 EST 2008
I get:
U MgHtmlController::GetMapImage(MgMap*, MgSelection*,
std::basic_string<wchar_t, std:: char_traits<wchar_t>, std::
allocator<wchar_t>> const&, MgPropertyCollection*, bool, bool)
Which seems to be identical to what was in the error message
Cheers
Jo
Jack Lee-3 wrote:
> Hi,
> What do you get if you execute
> nm -C /home/joc/mgsvn/Web/src/HttpHandler/.libs/libMgHttpHandler.so|grep
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jo Cook
> Sent: Thursday, February 28, 2008 8:27 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] 2.0 rc4 build failing on Ubuntu 7.10
> Hi All,
> I had a working build of MGOS from svn that I wanted to upgrade to the
> latest and greatest (build 3038 is the one I now have), but the new build
> is
> now failing.
> I get all the way through to the final make, but this fails with the
> following error:
> Making all in CgiAgent
> make[3]: Entering directory `/home/joc/mgsvn/Web/src/CgiAgent'
> /bin/sh ../../../libtool --tag=CXX --mode=link g++  -O2 -g -pipe
> -march=i386
> -mcpu=i686 -fno-use-cxa-atexit -fexceptions   -o mapagent -version-info
> 7:0:0 -:0:0 -L../../../Oem/ACE/ACE_wrappers/ace
> -L../../../Oem/dbxml-2.3.10/install/lib -L../../../Common/CoordinateSystem
> -L../../../Common/MdfModel -L../../../Common/MdfParser
> -L../../../Common/Foundation -L../../../Common/Geometry
> -L../../../Common/PlatformBase -L../../../Common/MapGuideCommon
> -L../HttpHandler MapAgentGetParser.o CgiPostParser.o CgiResponseHandler.o
> MapAgentStrings.o EchoTest.o CgiAgent.o InitializeWebTier.o -lACE
> -lxerces-c
> -lMgFoundation -lMgGeometry -lMgPlatformBase -lMgMdfModel -lMgMdfParser
> -lMgHttpHandler
> libtool: link: warning: `-version-info' is ignored for programs
> g++ -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions
> -o
> .libs/mapagent MapAgentGetParser.o CgiPostParser.o CgiResponseHandler.o
> -L/home/joc/mgsvn/Oem/ACE/ACE_wrappers/ace
> -L/home/joc/mgsvn/Oem/dbxml-2.3.10/install/lib
> -L/home/joc/mgsvn/Common/CoordinateSystem
> -L/home/joc/mgsvn/Common/MdfModel
> -L/home/joc/mgsvn/Common/MdfParser -L/home/joc/mgsvn/Common/Foundation
> -L/home/joc/mgsvn/Common/Geometry -L/home/joc/mgsvn/Common/PlatformBase
> -L/home/joc/mgsvn/Common/MapGuideCommon
> -L/home/joc/mgsvn/Web/src/HttpHandler -lACE -lxerces-c
> /home/joc/mgsvn/Common/Foundation/.libs/libMgFoundation.so
> /home/joc/mgsvn/Common/Geometry/.libs/libMgGeometry.so
> /home/joc/mgsvn/Common/PlatformBase/.libs/libMgPlatformBase.so
> /home/joc/mgsvn/Common/MdfModel/.libs/libMgMdfModel.so
> /home/joc/mgsvn/Common/MdfParser/.libs/libMgMdfParser.so
> -Wl,/usr/local/mapguideopensource/lib -Wl,--rpath
> -Wl,/usr/local/mapguideopensource/webserverextensions/lib
> /home/joc/mgsvn/Web/src/HttpHandler/.libs/libMgHttpHandler.so: undefined
> reference to `MgHtmlController::GetMapImage(MgMap*, MgSelection*,
> std::basic_string<wchar_t, std::char_traits<wchar_t>,
> std::allocator<wchar_t> > const&, MgPropertyCollection*, bool, bool)'
> collect2: ld returned 1 exit status
> make[3]: *** [mapagent] Error 1
> make[3]: Leaving directory `/home/joc/mgsvn/Web/src/CgiAgent'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/home/joc/mgsvn/Web/src'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/joc/mgsvn/Web'
> make: *** [all-recursive] Error 1
> I remember a similar problem a few months ago to do with a missing
> reference
> to liblibjson, which was resolved by adding some extra libraries to
> cgiagent/makefile.am, but I'm not really sure where to go with this.
> Can anyone help?
> Many thanks
> Jo
> http://www.nabble.com/2.0-rc4-build-failing-on-Ubuntu-7.10-tp15736315s16610p15736315.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/2.0-rc4-build-failing-on-Ubuntu-7.10-tp15736315s16610p15738163.html
