[mapguide-users] Issue with MGOS2.0 Beta 2
BradM masonb at dfo-mpo.gc.ca
Tue Jan 1 19:58:02 EST 2008
We had problems installing mapguide and also problems with mapguide corupting
databases. It was recommended that we switch to Apache to avoid these
problems.  So we switched over quite a while ago and Apache is working fine.
However, we have failed in our attemps to install the new beta MGOS 2.0
while keeping MGE2008 installed at the same time.
Ivan Milicevic-3 wrote:
> Why do you use Apache instead IIS? Is it faster?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BradM
> Sent: Tuesday, January 01, 2008 7:18 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Issue with MGOS2.0 Beta 2
> Thanks Andy,  we are using Apache with MGE2008 but Jim O. had problems
> installing some dll files with the new beta software.  I like the idea
> of
> using the VMW software for testing so we will not corrupt or lose
> anything.
> Please let me know if I can test your new demo site via email if
> possible.
> thanks
> Andy Morsell wrote:
>> Brad,
>> I also had some issues installing and getting it to work alongside MGE
>> 2008
>> with both running IIS.  I decided to not go the IIS / Apache
> side-by-side
>> route (although I'm sure that would have worked fine).  Instead, I
> decided
>> to invest the time to set up some VMWare virtual machines so that I
> can
>> more
>> easily test the releases in isolated environments with a minimum of
>> opportunity for conflicts.  I am currently testing MGOS 2 Beta
>> successfully
>> this way and so far it is working well.  I have by no means been able
> to
>> load test or put it through it's paces, so don't have much feedback on
>> stability yet.
>> http://www.vmware.com/products/server/
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> http://www.SpatialGIS.com
>> Sent: Tuesday, January 01, 2008 9:41 AM
>> Subject: Re: [mapguide-users] Issue with MGOS2.0 Beta 2
>> Happy New Year.  Have you or anyone found any improvements with the
> new
>> Beta
>> MGOS?  Is it faster?  Is it stable? We are having problems installing
> it
>> along side MGE 2008 and I am wondering if it is worth it at this
> point.
>> thanks
>> mauro1970 wrote:
>>> Layers that use custom symbols don't display correctly. Symbols now
>>> appear on the left bottom corner. They showed ok in 1.2.
>> View this message in context:
> http://www.nabble.com/Issue-with-MGOS2.0-Beta-2-tp14563310s16610p1456841
> 4.ht
>> ml
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Issue-with-MGOS2.0-Beta-2-tp14563310s16610p1456873
> 1.html
View this message in context: http://www.nabble.com/Issue-with-MGOS2.0-Beta-2-tp14563310s16610p14572079.html
