[mapguide-users] Sql For Data Filter
Kenneth, GEOGRAF A/S
ks at geograf.dk
Wed Jan 2 04:51:50 EST 2008
Yes, that is what the "Ad Hoc Queries" does.
Perhaps you want to combine it with "Dynamic Themes"?
Regards, Kenneth, GEOGRAF A/S
ary sucaya skrev:
> Thanks Kenneth,
> I'm looking for sample code of making data filter programmatically and
> save in into current session.
> Regards,
> Ary Sucaya
> ----- Original Message ----
> From: "Kenneth, GEOGRAF A/S" <ks at geograf.dk>
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Sent: Wednesday, January 2, 2008 10:08:48 AM
> Subject: Re: [mapguide-users] Sql For Data Filter
> I think the "Query" part of the "Generic Tasks" is close to what you want:
> http://data.mapguide.com/mapguide/gt/index.php
> More samples:
> http://mapguide.osgeo.org/livegallery.html
> ary sucaya skrev:
>> Great!, I will try
>> I was wondering if there is a sample code for it..
>> Thank v much..
>> regards,
>> Ary Sucaya
>> Sent: Wednesday, January 2, 2008 8:46:05 AM
>> I don't have a list of what the different providers support.
>> I have used the OGR provider, and it supports PostGIS and limited SQL.
>> My approach to your problem would be to start out with the layer hidden.
>> When you want to display the correct district, you read out the WKT
>> of the feature (district) you want to perform the intersection test with.
>> Then you update the filter on the layer to reflect this:
>> GeoColumn Intersects GEOMFROMTEXT('....wkt....')
>> Then show the layer.
>> You should copy the layer into the session repository before altering it.
>> If you want to theme it, you can create multiple copies of the layer
>> and apply theming to the individual layers.
>> ary sucaya skrev:
>>> Thank for your reply,
>>> Can you pls inform me what provider support full sql syntax? I use
>>> postgis and it seem to be not support full sql syntax.
>>> In my case, i can't use join tables because i need spatial
>>> relationship between 2 tables. For examples in Mapguide sample there
>>> are 11 districts. At first time, i want to hide parcels. Then i want
>>> to make a query to show parcels in particular distric and i want
>>> maps show parcels which are in that query result. In this case, join
>>> between two tables may not help me. I make use spatial relationship
>>> such as intersects or within in this case.
>>> Regards,
>>> Ary Sucaya
>>> Sent: Tuesday, January 1, 2008 5:25:05 PM
>>> That depends on the provider. Some providers supports full SQL syntax.
>>> I can't see how you can join tables with a filter, as that is the
>>> equvalent of the SQL WHERE construct.
>>> You can try to setup a Join on the featuresource, but I have had
>>> limited success with joins.
>>> ary sucaya skrev:
>>>> Hello,
>>>> I was wondering if i can put a complex sql statement at 'Filter
>>>> applied to data' textbox on Layer Editor. I need to show some data
>>>> from my postgis table and sql to select this data involving 2 or
>>>> more table.
>>>> Regs,
>>>> ary sucaya
>>>> Never miss a thing. Make Yahoo your homepage.
>>>> <http://us.rd.yahoo.com/evt=51438/*http://www.yahoo.com/r/hs>
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Looking for last minute shopping deals? Find them fast with Yahoo!
>>> Search.
>>> <http://us.rd.yahoo.com/evt=51734/*http://tools.search.yahoo.com/newsearch/category.php?category=shopping>
>> Be a better friend, newshound, and know-it-all with Yahoo! Mobile.
>> Try it now.
>> <http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ%20>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080102/913e3a7b/attachment.html
