Re[mapguide-users] nderingService and DPI (How to change DPI
before rendering)
simon hope
simonh at geobiz.co.nz
Thu Jan 3 15:35:08 EST 2008
Luis,
Find attached file which contains my code.
The methods that may help are:
getImageByMapAgent()
getImageUsingRenderService()
The first method basically constructs a request to the cgi - I was playing
around with dpi and display width and height to get the quality of image i
wanted - I seem to remember 'loosing' data when i tried to produce a large
image (for example I would try to create a large image using parcel boundary
data and aerial photography and the rasters would not appear in the output -
note the GetImageFromURL() method has code included to timeout (when
producing a large image then you may want to comment this out).
In the second method I had to use a round about way to get the extent of the
map, i also tried to preserve selection in the map - if i remember correctly
the RenderMap() method is overloaded and I tried a number of versions but
wasn't quite getting the results i wanted which i why i looked at the direct
route to MapAgent.
Hope this helps
S
http://www.nabble.com/file/p14604759/OutputImage.aspx.cs OutputImage.aspx.cs
lmbap wrote:
> I'm trying to use your code and the problem with the rendering service is
> that the image is created empty.
> With the size of the map displyed but without any contents inside.
> Can you, as you said, look again to see what is happening?
> ty
> Luis
> simon hope wrote:
>> Scott,
>> I was looking at creating PDF's a couple of months back and I used a
>> couple of methods - both the rendering service and the direct call to
>> mapagent via http - i ended up using the direct call to mapagent as my
>> preferred method - here is some sample code that i used (c#)
>> Method 1 - rendering service
>> //method for getting extent
>> int dpi = map.GetDisplayDpi();
>> double metPerUnit = 100000;
>> double metPerPxl = 0.0254 / dpi;
>> double sesMapScale = map.GetViewScale();
>> int sesScrnW = map.GetDisplayWidth();
>> int sesScrnH = map.GetDisplayHeight();
>> double midX = map.GetViewCenter().GetCoordinate().GetX();
>> double midY = map.GetViewCenter().GetCoordinate().GetY();
>> double sesLLX = midX - ((sesMapScale * sesScrnW * metPerPxl) /
>> metPerUnit) / 2;
>> double sesURX = ((sesMapScale * sesScrnW * metPerPxl) /
>> metPerUnit) / 2 + midX;
>> double sesLLY = midY - ((sesMapScale * sesScrnH * metPerPxl) /
>> metPerUnit) / 2;
>> double sesURY = ((sesMapScale * sesScrnH * metPerPxl) /
>> metPerUnit) / 2 + midY;
>> //get the map envelope
>> MgEnvelope env = new MgEnvelope(sesLLX, sesLLY, sesURX, sesURY);
>> //set the selection
>> MgSelection sel = new MgSelection(map);
>> //set the rendering service
>> MgRenderingService renderingSrvc =
>> siteConnection.CreateService(MgServiceType.RenderingService) as
>> MgRenderingService;
>> //set the colour
>> MgColor bgcolor = new MgColor(0, 0, 0, 0);
>> MgByteReader byteReader = renderingSrvc.RenderMap(map, sel, env,
>> sesScrnW, sesScrnH, bgcolor, "png");
>> MgGeometryFactory gFactory = new MgGeometryFactory();
>> MgCoordinate coord =
>> gFactory.CreateCoordinateXY(map.GetViewCenter().GetCoordinate().GetX(),
>> map.GetViewCenter().GetCoordinate().GetY());
>> long byteReaderSize = byteReader.GetLength();
>> //Create an MgByteSink and save to the file system
>> MgByteSink byteSink = new MgByteSink(byteReader);
>> string fileName = "c:\\temp\\RenderMap.png";
>> byteSink.ToFile(fileName);
>> Method 2 - http request
>> call.....
>> System.Drawing.Image bmp =
>> GetImageFromURL("http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=GETMAPIMAGE&VERSION=1.0.0&SESSION="
>> + tbSessionID.Text + "&MAPNAME=" + tbMapName.Text + "&LOCALE=en&FORMAT="
>> + format + "&SETVIEWCENTERX=" + Convert.ToString(x) + "&SETVIEWCENTERY="
>> + Convert.ToString(y) + "&SETVIEWSCALE=" + Convert.ToString(scale) +
>> "&SETDISPLAYDPI=" + strDpi + "&SETDISPLAYWIDTH=" + dispW +
>> "&SETDISPLAYHEIGHT=" + dispH);
>> method....
>> private System.Drawing.Image GetImageFromURL(string strURL)
>> System.Drawing.Image retVal = null;
>> try
>> HttpWebRequest request =
>> (HttpWebRequest)HttpWebRequest.Create(strURL);
>> //request.Timeout = 15000; // 5 seconds in milliseconds
>> //request.ReadWriteTimeout = 20000; // allow up to 20
>> seconds to elapse
>> // execute the request
>> HttpWebResponse response =
>> (HttpWebResponse)request.GetResponse();
>> retVal =
>> System.Drawing.Image.FromStream(response.GetResponseStream());
>> catch (Exception)
>> retVal = null;
>> return retVal;
>> I can't remember quite where i was experiencing problems with the
>> rendering service but could looki again if you need more help
>> Cheers
>> Simon
>> Kenneth, GEOGRAF A/S wrote:
>>> I see your point.
>>> The runtime map has a DisplayDPI property, but it is readonly.
>>> I also assumed that the API had the same parameters as the actual
>>> service call, but not in this case.
>>> You can use the "SETDATAEXTENT" call to set the DPI, but it does change
>>> current DPI.
>>> You should be able to save a copy of the runtime map though.
>>> Regards, Kenneth, GEOGRAF A/S
>>> Scott Hameister skrev:
>>>> That is true...But that is using an FCGI call and not the Rendering
>>>> Service API...The API has no mention of DPI...I would think the API
>>>> would have all the same capabilities that an FCGI call has?
>>>> I started using the FCGI calls...but it became annoying because
>>>> changing the FCGI DPI...caused the Current maps DPI to change...
>>>> If I created a new Session to call the FCGI on, then my selection XML
>>>> from the original Sessions map didn't work in the New Session, because
>>>> the Layer ID changed...etc.
>>>> *From:* mapguide-users-bounces at lists.osgeo.org
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
>>>> *Kenneth, GEOGRAF A/S
>>>> *Sent:* Monday, November 12, 2007 1:21 PM
>>>> *To:* MapGuide Users Mail List
>>>> *Subject:* Re: [mapguide-users] RenderingService and DPI (How to
>>>> change DPI before rendering)
>>>> I have no used the ColdFusion stuff that you are using, but the call
>>>> to GetMapImage does have a DPI parameter, that you can use.
>>>> I have no trouble getting the images as I want, although the PDF
>>>> format usually reduces quality a bit.
>>>> Try looking at the code in the viewer for "Printable Page", as it
>>>> shows how to use the calls.
>>>> I can send anyone interested sample PDFs of the same map stream at
>>>> different screen resolutions
>>>> <mailto:mapguide-users-bounces at lists.osgeo.org>
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Scott
>>>> Hameister
>>>> *Sent:* Monday, November 12, 2007 12:00 PM
>>>> *To:* 'MapGuide Users Mail List'
>>>> *Subject:* [mapguide-users] RenderingService and DPI (How to change
>>>> How do I change the DPI that The Rendering Service Uses when Creating
>>>> a map...
>>>> The Streamed Image from the rendering service is being poured into a
>>>> PDF file...the problem is that the quality of the PDF varies based on
>>>> the Resolution my Screen is at when I render the Stream, instead of
>>>> being consistent in the PDF. If I'm at 1024 x 768 the PDF map is
>>>> grainier than if I'm at 1920x1200 resolution when I stream the image
>>>> How can I address this to make the PDF quality the same for all users?
>>>> <cfset newMap =
>>>> renderingSrvc.rendermap(map,mgselection,realCenter,Javacast("DOUBLE",SesMapScale),Javacast
>>>> ("INT",SesScrnW),Javacast("INT",SesScrnH),mapcolor,"PNG")>
>>>> Above Is my Coldfusion call...
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/RenderingService-and-DPI-%28How-to-change-DPI-before-rendering%29-tp13710681s16610p14604759.html
