[mapguide-users] Installing MapAgent on a different server
Luiz Marcio Viana lmarcio at parsrio.com.br
Fri Jan 11 12:09:24 EST 2008
I checked the FastCGIAgent and I found references to MgInitializeWebTier in
it.
It uses APPL_PHYSICAL_PATH to locate the webconfig.ini and when fail the
GetModuleFileName().
I set in the webconfig.ini the address of my site server, using the key
IpAddress of SiteConnectionProperties section.
But, when I try to make a request using the mapagent.exe I get the following
error.
Cannot establish connection.
Cannot establish connection. Exception occurred in method
MgServerConnection.Open at line 98 in file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\common\mapguidecommon\Services/ServerConnection.cpp
I check my server and it is up and it is reacheable from the machine running
the mapagent.exe.
Thanks,
Luiz Marcio
----- Original Message -----
From: "Luiz Marcio Viana" <lmarcio at parsrio.com.br>
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Sent: Friday, January 11, 2008 10:43 AM
Subject: [mapguide-users] Installing MapAgent on a different server
> Hi,
> I'm trying to install the mapagent.exe on a different server than the site
> server.
> But, there are not any configuration file to set the mapagent.exe to
> redirect the requests to a different server.
> The webconfig.ini file can change only the connection of the application
> using the API.
> How can I do this job.
> Thanks,
> Luiz Marcio
> mapguide-users mailing list
