[mapguide-users] MG1.2.0: OGRProvider connection to PostgreSQL
Traian Stanev traian.stanev at autodesk.com
Sat Jan 12 02:23:38 EST 2008
Try it with just the DataSource and ReadOnly properties. It will pick up the user name and password from the DataSource string, so you should not specify separate username and password connection properties. Also try running the mapguide server from the command line using the /interactive flag. It may print out useful information when opening OGR connections.
Traian
From: mapguide-users-bounces at lists.osgeo.org [mapguide-users-bounces at lists.osgeo.org] On Behalf Of schwanzy [schwanzy at gmail.com]
Sent: Friday, January 11, 2008 10:42 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] MG1.2.0: OGRProvider connection to PostgreSQL
Hello,
    how do I connect MapGuide OS 1.2.0 to PostgreSQL 8.1?
I downloaded http://download.osgeo.org/fdo/3.2.2/OGRProvider-3.2.2.win32.zip, extracted to FDOs directory, then added:
  <FeatureProvider>
    <Name>OSGeo.OGR.0.1</Name>
    <DisplayName>OSGeo FDO Provider for OGR </DisplayName>
    <Description>Access to OGR data sources. </Description>
    <IsManaged>False</IsManaged>
    <Version>3.2.2.0</Version>
    <FeatureDataObjectsVersion>3.2.2.0</FeatureDataObjectsVersion>
    <LibraryPath>C:\Programmi\MapGuideOpenSource\Server\Bin\FDO\OGRProvider.dll</LibraryPath>
  </FeatureProvider>
to providers.xml and restarted MGOS.
In MapGuide Studio 2008:
    [connection properties]
       DataSource            PG: host=10.1.1.150 dbname=myDB user=myUser password=myPassword
       ReadOnly               FALSE
       username:            myUser
       password:            myPassword
"Verify connection" is ok, but when I try to see a preview it complains:
       Invalid argument(s): [1] = "0" The value is invalid because it is too large.
and there is no log in /var/log/postgresql/postgresql-8.1-main.log.
If I set:
       ReadOnly               FALSE
       username:            myUser
"Verify connection" complains:
    An exception occurred in FDO component. Connect failed: PQconnectdb failed. FATAL role "SYSTEM" does not exist
and in /var/log/postgresql/postgresql-8.1-main.log I see that MG tried tto connect as SYSTEM and not as the specified user.
Any idea?
Regards
