[mapguide-users] King Oracle Problem
JeromeA PraktikantTA3 at stuttgart-airport.com
Tue Jan 15 03:40:05 EST 2008
Hm, jes could be. But I also tried to install Oracle 10g client, wich works,
and deinstalled the 9i Client. So there is no Instant Client necessary,
isn't it?
Simon Pelicon wrote:
> Did you by mistake downland 64bit version of oracle instant client
> instead of 32bit?
> Simon
> JeromeA wrote:
>   Hi,
> I've got a MGE 2008 trial, with FDO 3.2.2. I downloaded Fing for 3.2.2. I
> restarted several times.
> I also tried the dependency walker wich shows a few missing files (see
> attached image).
> Thanks for your help ,
> Jerome
>     Hi,
> Which version of MapGuide do you have?
> There are providers v0.7.3 for different FDO versions (3.1 ,3.2 and
> .3.2.2)
> Do you restart MG server after changing provider files,xml etc...?
> You can also check which files are missing or wrong , using "Dependency
> walker" http://www.dependencywalker.com/
> With Dependency W. open KingProvider.dll.
> Simon
>   http://www.nabble.com/file/p14833719/dependency.jpg
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/King-Oracle-Problem-tp14804675s16610p14833984.html
