[mapguide-users] King Oracle Problem
JeromeA
PraktikantTA3 at stuttgart-airport.com
Tue Jan 15 04:12:04 EST 2008
Thank you for your help,
it is working now! I've deleted the oci files in the fdo folder.
:clap:
Jerome
zspitzer wrote:
> if you do use the instant client version, make sure the oci*.dll's are in
> the bin\FDO directory and not in a subdirectory
> z
> On Jan 15, 2008 7:45 PM, Simon Pelicon <simon at sl-king.com> wrote:
>> No, Instant Client is not necessary if you use Oracle 10g client.
>> In this case you have to download King Provider for
>> <http://www.sl-king.com/fdooracle/download/FdoKingOracle_Win32_FDO_3_2_2_v0_7_3.zip>v0.7.3
>> Windows 32-bit provider for Oracle 10.2
>> Client<http://www.sl-king.com/fdooracle/download/FdoKingOracle_Win32_FDO_3_2_2_v0_7_3.zip>
>> and not for Instant Client.
>> Simon
>> JeromeA wrote:
>> Hm, jes could be. But I also tried to install Oracle 10g client, wich
>> works,
>> and deinstalled the 9i Client. So there is no Instant Client necessary,
>> isn't it?
>> Simon Pelicon wrote:
>> Did you by mistake downland 64bit version of oracle instant client
>> instead of 32bit?
>> Simon
>> JeromeA wrote:
>> Hi,
>> I've got a MGE 2008 trial, with FDO 3.2.2. I downloaded Fing for 3.2.2. I
>> restarted several times.
>> I also tried the dependency walker wich shows a few missing files (see
>> attached image).
>> Thanks for your help ,
>> Jerome
>> Hi,
>> Which version of MapGuide do you have?
>> There are providers v0.7.3 for different FDO versions (3.1 ,3.2 and
>> .3.2.2)
>> Do you restart MG server after changing provider files,xml etc...?
>> You can also check which files are missing or wrong , using "Dependency
>> walker" http://www.dependencywalker.com/
>> With Dependency W. open KingProvider.dll.
>> Simon
>> http://www.nabble.com/file/p14833719/dependency.jpg
>> mapguide-users mailing
>> listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
>> mapguide-users mailing list
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://www.nabble.com/King-Oracle-Problem-tp14804675s16610p14834732.html
