[mapguide-users] Fusion
Berdel, Brian brian.berdel at mcmtrans.com
Thu Jan 17 15:27:42 EST 2008
Ok, I must be missing something when trying the samples...Please help.
I was using IIS and the .NET config, but now I am using bundled php
-Brand new computer XPsp2
-Mapguide 2.0 Beta2 just installed with the bundled php config
-I loaded the Sheboygan Sample Data and the Fusion Sample package.
As far as I can tell, this is all I should need to do.
I then went to
http://localhost:8008/mapguide/fusion/templates/mapguide/slate/index.htm
l?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexibleLa
youts%2fSlate.ApplicationDefinition
The application loads, but it does not load the district layer, the
scale textbox is all the way to the left, and the layers do not turn on
or off...Zooming, Selecting, etc does work.
What is going on?  Is that all I need to do?
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer
Sent: Wednesday, January 16, 2008 10:15 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Fusion
Hi Bill,
Fusion is designed to work with other scripting languages on the server
side but porting the existing scripts to the other languages has not
been done.  This would be an ideal candidate for contributions to the
open source community.
Cheers
Paul
On 10-Jan-08, at 8:06 AM, Kimbrell, Bill wrote:
> Are there plans for Fusion to work with .NET?
> And if so, any idea of dates ?
> Thanks, Bill Kimbrell
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike
> Adair
> Sent: Wednesday, January 09, 2008 5:17 PM
> Fusion will only work with PHP at this point.
> For the layer toggling issue, I'm not seeing this bug. Are you using a
> tiled map? If so, layer toggling won't work because the tiles are
> served
> up with layers on or off as specified by the mapguide server. If
> you're not using a tiled map, is there a public instance of your app
> that we can look at?
> Mike Adair
> Berdel, Brian wrote:
>> Not getting much of a response here...So I'll try another question.
>> Does Fusion work with the .NET configuration of IIS or PHP only? I
>> have tried it the samples on multiple machines and cannot get it to
>> work. Has anyone got it to work with .NET?
>> *From:* mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
>> *Berdel,
>> Brian
>> *Sent:* Wednesday, January 09, 2008 1:11 PM
>> *To:* MapGuide Users Mail List
>> *Subject:* RE: [mapguide-users] Fusion - Layers do not turn off / on
>> Some layers actually never load on the samples, and I noticed in
>> firefix that the status bar says "transferring data from local host"
>> it just hangs there...
>> Any ideas?
>> *Berdel,
>> Brian
>> *Sent:* Wednesday, January 09, 2008 10:10 AM
>> Is everyone else's working correctly? Just wondering if it is
>> something I did, or didn't do...If I view a map in a regular viewer
> the
>> layers work as they are supposed to...However, if I view a fusion
> sample
>> or one of my maps in fusion, they do not respond to the checkboxes...
>> If I try to turn them on or off, nothing happens...
>> *Berdel,
>> Brian
>> *Sent:* Tuesday, January 08, 2008 4:58 PM
>> *Subject:* [mapguide-users] Fusion - Layers do not turn off / on
>> Just started testing fusion and 2.0...Is anyone else having issues
> where
>> their layers will not turn on or off once the map is loaded?
>> The fusion samples load up correctly, but when I attempt to turn a
>> layer on or off, the screen just flashes and nothing happens. The
>> other normal mapping functionalities are available.
>> Thanks,
>> -Brian
>> *Berdel,
>> Brian
>> *Sent:* Tuesday, January 08, 2008 4:42 PM
>> *Subject:* [mapguide-users] Symbols 2.0
>> Sorry if this is a known issue, but I did a quick search and couldn't
>> find anything...
>> All of my symbols are appearing on top of each other in the lower
>> left
>> hand corner of my map in 2.0 beta2. Anyone else?
>> Thanks,
>> Brian
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Marc
>> Pfister
>> *Sent:* Tuesday, January 08, 2008 3:31 PM
>> *Subject:* RE: [mapguide-users] Mapguide with no map...
>> I am using the Sheboygan data, and I checked the extents and they are
>> correct. I'm confused as to why the Sheboygan dataset is throwing
>> "Unsupported coordinate system code" when I'm trying to output to
>> 4326. That shouldn't happen.
>> *Kenneth, GEOGRAF A/S
>> *Sent:* Tuesday, January 08, 2008 12:06 PM
>> *Subject:* Re: [mapguide-users] Mapguide with no map...
>> You should try with some data that you know the bounds of (Sheboygan
>> perhaps?).
>> I have seen many cases, where the auto-calculated map extents are
> wrong.
>> Regards, Kenneth, GEOGRAF A/S
>> Marc Pfister skrev:
>> The MG error log doesn't show any errors. The Admin log only shows
>> successes.
>> I did manage to generate an error message of sorts. If I use MapAgent
>> to generate a WMS GetMap request, using the default values it gives
>> for the Sheboygan dataset ( EPSG 4326 and lat lon bounds in the -87,
>> 43 range), I get this error:
>> The coordinate system conversion failed.
>> Unsupported coordinate system code. The coordinate system conversion
>> failed.
>> Exception occurred in method
>> MgCoordinateSystem.ConvertCoordinateSystemCodeToWkt at line 972 in
>> file CoordinateSystem/CoordinateSystem.cpp
>> Proj is the bin folder, and executing ./proj returns the useage:
> message.
>> I'm not sure what's going on, and without any more clues I might just
>> reinstall and see what happens.
>> <mailto:mapguide-users-bounces at lists.osgeo.org>
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Ivan
>> Milicevic
>> *Sent:* Monday, January 07, 2008 11:55 PM
>> Anything in MG server log???
>> Pfister
>> *Sent:* Tuesday, January 08, 2008 1:50 AM
>> *To:* mapguide-users at lists.osgeo.org
>> <mailto:mapguide-users at lists.osgeo.org>
>> *Subject:* [mapguide-users] Mapguide with no map...
>> I recently installed Mapguide OS on Ubuntu using the wiki pages and
>> everything seemed to install correctly.
>> Apache starts and responds fine. I get directory listings and simple
>> pages or parts of pages.
>> Mapguide starts fine. Watching the output from starting the startup
>> shell script, it says it starts up and is using the Proj 4 library.
>> Map Admin works fine. I can load data packages, etc
>> However, I can't seem to get any map output.
>> WebStudio works, though never draws any sample maps (though it only
>> wants to look at 127.0.0.1, which isn't the right place to look on my
>> system)
>> The sample maps, like Sheboygan, don't seem to draw anything. I get a
>> blank page in the brower when I use the phpviewersample.
>> MapAgent works for requests like GetCapabilities, but also doesn't
>> draw any maps with the related tools. I don't know the extents of the
>> sample data, so maybe that's why I can't get an output from it.
>> In any case, I never see any error messages show up at the terminal.
>> Is there a way to make it more verbose?
>> My next step will be to load a sample shapefile of which I know the
>> extents so I can give it more complete request for an area to render.
>> Are there any other troubleshooting steps I should take?
>> n
>> Marc Pfister
>> Geospatial Data Manager
>> ENPLAN
>> mpfister at enplan.com <mailto:mpfister at enplan.com> 530/221-0440 x108
>> 530/221-6963 Fax
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org <mailto:mapguide-
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
