[mapguide-users] Changing Visibility for one layer affects others
nclayton nclayton at gmail.com
Tue Jan 22 11:00:36 EST 2008
A little more info on the situation...if I toggle the raster layer on while I
am outside of its visibility range, the other layers are still visible. Once
I get within range and the raster layer is displayed, I lose my other
layers. Except for a couple of text layers.
After this point, the layers are not visible again until I begin a new
session.
nclayton wrote:
> It is at the very bottom of the drawing stack. The layer is pulling from
> an aliased folder on the server and contains 595 ecw files. I'm not sure
> if that could be a factor in this issue, especially since the layers do
> not return once the raster layer is set to no longer be visible.
> andrew.demerchant wrote:
>> Without looking at your code, I'm wondering if maybe your raster image
>> layer is above your other layers. I'd check your layer ordering. I know
>> how to do that in Mapguide Studio or Web Studio, but not so sure using
>> code.
>> Andrew
>> nclayton wrote:
>>> Hi all,
>>> I am trying to add functionality to toggle raster images on and off to
>>> my
>>> map. I have the raster images on a layer called aerial. I am calling a
>>> php
>>> page with the following function call in the scriptFrame:
>>>         toggleLayer($sessionId,$mapName,"aerial");
>>> The function is:
>>> 	function toggleLayer($sessId,$mapName,$layerName){
>>> 		try{
>>> 			$userInfo = new MgUserInformation($sessId);
>>> 			$siteConnection = new MgSiteConnection();
>>> 			$siteConnection->Open($userInfo);
>>> 			$ressvc =
>>> $siteConnection->CreateService(MgServiceType::ResourceService);
>>> 			$map = new MgMap();
>>> 			$map->Open($ressvc,$mapName);
>>> 			$tlyr = $map->GetLayers()->GetItem($layerName);
>>> 			$tlyr->SetVisible(!($tlyr->GetVisible()));
>>> 			$map->Save($ressvc);
>>> 		}catch(Exception $e){
>>> This is causing the layer to become visible, but it is also causing
>>> other
>>> layers to not be visible.
>>> I've made a page with images showing what is happening, and it is
>>> located
>>> at:
>>> http://www.tscmaps.com/issue.htm http://www.tscmaps.com/issue.htm
>>> Thank you for your help
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Changing-Visibility-for-one-layer-affects-others-tp15021169s16610p15021714.html
