[mapguide-users] Changing Visibility for one layer affects others
nclayton
nclayton at gmail.com
Tue Jan 22 12:13:41 EST 2008
yeah...I smacked myself after posting that...good ole MS
I changed the layer name that I was passing my code, and it worked like I
wanted, so this isn't a code issue. Maybe the size of the raster layer is
causing the mapagent to bomb out before it can process the sdfs?
James Card wrote:
> On Tue, 22 Jan 2008 08:25:50 -0800, nclayton <nclayton at gmail.com> wrote:
>> I look on the server and the folder containing the sdf files has a gray
>> checkmark for Read Only. I uncheck this, pan the map a little to cause a
>> refresh and get the same error message in the response and the checkmark
>> is back.
> This is normal behavior for folders; you'l have to look at the attributes
> on the files themselves.
> James Card
> California CAD Solutions, Inc.
> 209 578-5580 Voice
> 209 521-6493 FAX
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Changing-Visibility-for-one-layer-affects-others-tp15021169s16610p15023552.html
