[mapguide-users] Urgent !!!! - Cannot Create any more
connections to FDO provider
Pascal Coulon
pascal.coulon at atkinsglobal.com
Mon Jan 28 08:59:59 EST 2008
Hi there,
I have the same problem. I have implemented a real time application which
update feature attributes every 30 seconds. After 20 iterations, the systen
hangs and then I get the same error Cannot Create any more connections to
FDO provider. Any help would much appreciated. I have very similar code to
Mark's one.
regards,
Mark Pendergraft wrote:
> Okay,
> I have a feature source, which contains quarters of sections.. I have
> written a program to create multipolygons of the quarter polygons and
> add the data from the individual polygons.
> It works fine, except when I set it to iterate through the entire set.
> Inside a loop I set the feature reader to the selection
> Get the features, run a function to convert them to a multipolygon
> Then dispose of the featureReader, then change my filter, then repeat
> the loop
> I get through about 40 iterations before I crash and get the message
> "Cannot Create any more Connections to OSGeo.SDF FDO provider"
> My question is.... What is creating the FDO connection? I thought it
> was when I create the FeatureReader... but since I'm closing and
> disposing each time, I'm no longer sure. What can I do in order to make
> my site loop through several thousand iterations (many of which will be
> empty) read the resulting features and write them to new features?
> My loop looks like this:
> Do While rngI < 3
> filter = IncrementSecTwnRng(secI, twnI, rngI)
> queryOpt.SetFilter(filter)
> fr = featureService.SelectFeatures(New
> MgResourceIdentifier(lay.GetFeatureSourceId), lay.GetFeatureClassName,
> queryOpt)
> propertyCollection = CreateMultiPolygon(fr,
> lay.GetFeatureGeometryName)
> If Not propertyCollection Is Nothing Then
> batchPropertyCollection.Add(propertyCollection)
> End If
> fr.Close()
> fr.Dispose()
> Loop
> Thanks for the help!
> -Mark Pendergraft
> Ph: (425) 486-1252 Fx: (425) 486-6108 www.meadgilman.com
> <http://www.meadgilman.com/>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Cannot-Create-any-more-connections-to-FDO-provider-tp11694089s16610p14975874.html
