[mapguide-users] Fusion .NET API
Jason Birch
Jason.Birch at nanaimo.ca
Mon Jan 28 16:22:09 EST 2008
Paul, is there any magic around the technology name, and the name of the
directory and file extensions?
I'm asking because the typical extension for asp.net is aspx. So...
would you have to name the directory aspx, and set the technology name
to aspx?
Jason
-----Original Message-----
Subject: Re: [mapguide-users] Fusion .NET API
there is no documentation on the existing PHP scripts except what is
inline with the code. I would expect the process to be something like:
1) create MapGuide/asp directory
2) create a *.asp file for each *.php file in the php directory
3) rewrite each *.asp file in ASP. The PHP code should be pretty
readable and the MapGuide API is identical (or should be) so it is
just a matter of changing the syntax around I hope. I'm sure there
are different
To get Fusion to use the asp version of the files, you will need to
edit the config.json file and set the 'technology' from php to asp.
There will likely be small bugs in the framework that need to be fixed
at this point because we haven't actually used it with a different
technology yet.
