[mapguide-users] How to embed the map in my own web page?
dorra2007
dorrdor at yahoo.fr
Wed Jan 30 06:13:27 EST 2008
i have an error message: Invalid repository type.
Whereas the map is displayed in mapguide studio.
NB: I use postgis as data source.
Kenneth, GEOGRAF A/S wrote:
> Yes, the mapviewerajax should be configured with the correct default page.
> If you use the "mapviewerjava", you must add ajaxviewer.jsp page name.
> The full url becomes:
> /mapguide/mapviewerjava/ajaxviewer.jsp?weblayout=Library://mylayout.WebLayout&username=Anonymous&password=
> Regards, Kenneth, GEOGRAF A/S
> dorra2007 skrev:
>> Thank you Kenneth for the code segment;
>> But there is no folder named mapviewerajax; so I have changed it to
>> mapviewerjava. I have tried it and the result is the title (This is my
>> webpage with an embedded map!)+ blank: the map isnot displayed (instead
>> of
>> the map lays a blank square.)
>> Have you an idea about what the problem can be?
>>> Yes, it is possible.
>>> My favorite method is to embed the Map in an Iframe:
>>> <html>
>>> <body>
>>> <h1>This is my webpage with an embedded map!</h1>
>>> <iframe
>>> src="/mapguide/mapviewerajax/?weblayout=Library://mylayout.WebLayout&username=Anonymous&password="
>>> width="100%" height="100%"></iframe>
>>> </body>
>>> </html>
>>> By adding commands, do you mean from code?
>>> What sort of commands do you want to add, and why is Studio not an
>>> option?
>>> dorra2007 skrev:
>>>> Hello all;
>>>> I have one precise question: Is it possible to display the mapguide map
>>>> in
>>>> my own web page?
>>>> If yes; what should I do? And how could I add commands without using
>>>> mapguide studio?
>>>> Thank you in advance.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/How-to-embed-the-map-in-my-own-web-page--tp15130478s16610p15180082.html
