[mapguide-users] Oracle Max 10 Connections
Pascal Coulon
pascal.coulon at atkinsglobal.com
Wed Jan 30 07:01:45 EST 2008
Thank you very much for your reply. I have increased the number of
connections for autodesk.oracle to higher level. Unfortunatelly, whatever
the number of users (e.g. 60 users), I only got a maximum of 11 conenctions.
We are confident that oracle is properly set-up with a maximum amount of
session of 100. While executing the test, I had a total of 36 sessions.
Do you have reference on the maximum number of conenctions available in the
pool? Is there a maximum connection value which overides the configuration
parameters?
Regards,
Pascal
Bruce Dechant wrote:
> The connection limit for specific providers is specified in the
> serverconfig.ini file.
> Please check this setting:
> DataConnectionPoolSizeCustom
> Example of the above:
> DataConnectionPoolSizeCustom = Autodesk.Oracle:10
> If the above setting is not limiting the # of Oracle connections then the
> connection limit is controlled at the Oracle DB side.
> Note: Changing the setting in the serverconfig.ini file DOES NOT override
> what was set by the Oracle DBA. The setting in Oracle itself is what
> ultimately limits the # of concurrent connections.
> Thanks,
> Bruce
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Pascal Coulon
> Sent: Tuesday, January 29, 2008 1:01 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Oracle Max 10 Connections
> Hi There,
> We have a system based on MapGuide Enterprise, the Autodesk.Oracle
> provider
> and an Oracle 10G R2. I have built a load test using Visual Studio 2008.
> Every 5 seconds 60 new simultaneous users request a map.
> I noticed that whatever the number of users, I still have a maximum of 10
> active connections to the Oracle Instance. I believe that MapGuide must
> have
> a pool of connections to Oracle; which are recycled regularly. The issue
> is
> that if the number of users increases dramatically, the all system will be
> badly slow. Can somebody advise on the maximum numbers of connection we
> can
> hope with the Autodesk.Oracle provider. Can somebody also advise on a
> possible tuning?
> Any help would be appreciated.
> regards,
> Pascal
> http://www.nabble.com/Oracle-Max-10-Connections-tp15169231s16610p15169231.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Oracle-Max-10-Connections-tp15169231s16610p15180738.html
