[mapguide-users] Build MGOS 2.0 on SUSE linux
Dorin
did_1414 at yahoo.com
Tue Jul 1 06:32:00 EDT 2008
Hi everybody please help me. I tried to build the mapguide OS 2.0.1 on SUSE Linux and I received the following error on the building mapguide server process:
make[3]: Leaving directory `/usr/src/mapguide-2.0.1/Server/src/UnitTesting'
Making all in Core
make[3]: Entering directory `/usr/src/mapguide-2.0.1/Server/src/Core'
/bin/sh ../../../libtool --tag=CXX --mode=link g++ -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions -DACE_HAS_SVC_DLL=1 -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions -o mgserver -version-info 7:0:0 -R/usr/local/fdo-3.3.0/lib -R/usr/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace -R/usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore -R/usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwf -R/usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfemap -R/usr/src/mapguide-2.0.1/Oem/dbxml-2.3.10/install/lib -R/usr/src/mapguide-2.0.1/Common/CoordinateSystem/.libs -R/usr/src/mapguide-2.0.1/Common/MdfModel/.libs -R/usr/src/mapguide-2.0.1/Common/MdfParser/.libs -R/usr/src/mapguide-2.0.1/Common/Stylization/.libs -R/usr/src/mapguide-2.0.1/Common/Renderers/.libs -R/usr/src/mapguide-2.0.1/Common/Foundation/.libs -R/usr/src/mapguide-2.0.1/Common/Geometry/.libs
-R/usr/src/mapguide-2.0.1/Common/PlatformBase/.libs -R/usr/src/mapguide-2.0.1/Common/MapGuideCommon/.libs -R/usr/src/mapguide-2.0.1/Server/src/Common/Base/.libs -R/usr/src/mapguide-2.0.1/Server/src/Common/Cache/.libs -R/usr/src/mapguide-2.0.1/Server/src/Common/Manager/.libs -R/usr/src/mapguide-2.0.1/Server/src/Common/Thread/.libs -R/usr/src/mapguide-2.0.1/Server/src/Services/Drawing/.libs -R/usr/src/mapguide-2.0.1/Server/src/Services/Feature/.libs -R/usr/src/mapguide-2.0.1/Server/src/Services/Kml/.libs -R/usr/src/mapguide-2.0.1/Server/src/Services/Mapping/.libs -R/usr/src/mapguide-2.0.1/Server/src/Services/Rendering/.libs -R/usr/src/mapguide-2.0.1/Server/src/Services/Resource/.libs -R/usr/src/mapguide-2.0.1/Server/src/Services/ServerAdmin/.libs -R/usr/src/mapguide-2.0.1/Server/src/Services/Site/.libs -R/usr/src/mapguide-2.0.1/Server/src/Services/Tile/.libs -R/usr/src/mapguide-2.0.1/Server/src/UnitTesting/.libs -L/usr/local/fdo-3.3.0/lib
-L../../../Oem/ACE/ACE_wrappers/ace -L../../../Oem/DWFTK7.1/develop/global/src/dwfcore -L../../../Oem/DWFTK7.1/develop/global/src/dwf -L../../../Oem/DWFTK7.1/develop/global/src/dwfemap -L../../../Oem/dbxml-2.3.10/install/lib -L../../../Common/CoordinateSystem -L../../../Common/MdfModel -L../../../Common/MdfParser -L../../../Common/Stylization -L../../../Common/Renderers -L../../../Common/Foundation -L../../../Common/Geometry -L../../../Common/PlatformBase -L../../../Common/MapGuideCommon -L../Common/Base -L../Common/Cache -L../Common/Manager -L../Common/Thread -L../Services/Drawing -L../Services/Feature -L../Services/Kml -L../Services/Mapping -L../Services/Rendering -L../Services/Resource -L../Services/ServerAdmin -L../Services/Site -L../Services/Tile ServerCoreBuild.o -lACE -ldb_cxx -ldbxml -ldwfcore -ldwftk -ldwfemap -lexpat -lFDO-3.3.0 -lExpressionEngine -lxalanMsg -lxalan-c -lxerces-c -lxqilla -lMgFoundation -lMgGeometry -lMgPlatformBase
-lMgMapGuideCommon -lMgServerAdminService -lMgServerBase -lMgServerCache -lMgServerDrawingService -lMgServerFeatureService -lMgServerKmlService -lMgServerManager -lMgServerMappingService -lMgServerRenderingService -lMgServerResourceService -lMgServerSiteService -lMgServerThread -lMgServerTileService -lMgMdfModel -lMgMdfParser -lMgStylization -lMgRenderers ../../../Common/Security/libMgSecurity.a
libtool: link: warning: `-version-info' is ignored for programs
g++ -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions -DACE_HAS_SVC_DLL=1 -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions -o .libs/mgserver ServerCoreBuild.o -L/usr/local/fdo-3.3.0/lib -L/usr/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace -L/usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore -L/usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwf -L/usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfemap -L/usr/src/mapguide-2.0.1/Oem/dbxml-2.3.10/install/lib -L/usr/src/mapguide-2.0.1/Common/CoordinateSystem -L/usr/src/mapguide-2.0.1/Common/MdfModel -L/usr/src/mapguide-2.0.1/Common/MdfParser -L/usr/src/mapguide-2.0.1/Common/Stylization -L/usr/src/mapguide-2.0.1/Common/Renderers -L/usr/src/mapguide-2.0.1/Common/Foundation -L/usr/src/mapguide-2.0.1/Common/Geometry -L/usr/src/mapguide-2.0.1/Common/PlatformBase -L/usr/src/mapguide-2.0.1/Common/MapGuideCommon
-L/usr/src/mapguide-2.0.1/Server/src/Common/Base -L/usr/src/mapguide-2.0.1/Server/src/Common/Cache -L/usr/src/mapguide-2.0.1/Server/src/Common/Manager -L/usr/src/mapguide-2.0.1/Server/src/Common/Thread -L/usr/src/mapguide-2.0.1/Server/src/Services/Drawing -L/usr/src/mapguide-2.0.1/Server/src/Services/Feature -L/usr/src/mapguide-2.0.1/Server/src/Services/Kml -L/usr/src/mapguide-2.0.1/Server/src/Services/Mapping -L/usr/src/mapguide-2.0.1/Server/src/Services/Rendering -L/usr/src/mapguide-2.0.1/Server/src/Services/Resource -L/usr/src/mapguide-2.0.1/Server/src/Services/ServerAdmin -L/usr/src/mapguide-2.0.1/Server/src/Services/Site -L/usr/src/mapguide-2.0.1/Server/src/Services/Tile /usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore/.libs/libdwfcore /usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwf/.libs/libdwftk /usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfemap/.libs/libdwfemap /usr/lib/libexpat.so -lFDO-3.3.0
/usr/local/fdo-3.3.0/lib/libExpressionEngine.so /usr/local/fdo-3.3.0/lib/libFDO.so -L/usr/src/FDO/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/lib -L/usr/src/FDO/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/lib -lxalanMsg -lxalan-c -L/usr/src/mapguide-2.0.1/Oem/dbxml-2.3.10/xerces-c-src/lib -L/usr/lib -L/usr/src/mapguide-2.0.1/Common/Security /usr/src/mapguide-2.0.1/Server/src/Services/ServerAdmin/.libs/libMgServerAdminService.so /usr/src/mapguide-2.0.1/Server/src/Services/Drawing/.libs/libMgServerDrawingService.so /usr/src/mapguide-2.0.1/Server/src/Services/Feature/.libs/libMgServerFeatureService.so /usr/src/mapguide-2.0.1/Server/src/Gws/GwsCommon/.libs/libMgGwsCommon.so /usr/src/mapguide-2.0.1/Server/src/Gws/GwsQueryEngine/.libs/libMgGwsQueryEngine.so /usr/src/mapguide-2.0.1/Server/src/Services/Kml/.libs/libMgServerKmlService.so /usr/src/mapguide-2.0.1/Server/src/Services/Mapping/.libs/libMgServerMappingService.so
/usr/src/mapguide-2.0.1/Server/src/Services/Rendering/.libs/libMgServerRenderingService.so /usr/src/mapguide-2.0.1/Server/src/Services/Resource/.libs/libMgServerResourceService.so /usr/src/mapguide-2.0.1/Common/MapGuideCommon/.libs/libMgMapGuideCommon.so /usr/src/mapguide-2.0.1/Common/PlatformBase/.libs/libMgPlatformBase.so /usr/src/mapguide-2.0.1/Common/Geometry/.libs/libMgGeometry.so /usr/src/mapguide-2.0.1/Common/Foundation/.libs/libMgFoundation.so -lACE /usr/src/mapguide-2.0.1/Oem/gdal-1.4.4/.libs/libgdal.so /usr/lib/libjasper.so /usr/lib/libjpeg.so -lpng -lrt /usr/lib/libcurl.so /usr/lib/libidn.so -lssl -lcrypto -ldl -lz /usr/src/mapguide-2.0.1/Oem/proj-4.5.0/src/.libs/libproj.so -lMgSecurity /usr/src/mapguide-2.0.1/Server/src/Common/Base/.libs/libMgServerBase.so /usr/src/mapguide-2.0.1/Server/src/Common/Cache/.libs/libMgServerCache.so /usr/src/mapguide-2.0.1/Server/src/Common/Manager/.libs/libMgServerManager.so
/usr/src/mapguide-2.0.1/Oem/dbxml-2.3.10/install/lib/libxqilla.so -lnsl -lpthread -ldb_cxx -ldbxml /usr/src/mapguide-2.0.1/Server/src/Services/Site/.libs/libMgServerSiteService.so /usr/src/mapguide-2.0.1/Server/src/Common/Thread/.libs/libMgServerThread.so /usr/src/mapguide-2.0.1/Server/src/Services/Tile/.libs/libMgServerTileService.so /usr/src/mapguide-2.0.1/Common/MdfParser/.libs/libMgMdfParser.so /usr/src/mapguide-2.0.1/Common/MdfModel/.libs/libMgMdfModel.so -lxerces-c /usr/src/mapguide-2.0.1/Common/Stylization/.libs/libMgStylization.so /usr/src/mapguide-2.0.1/Common/Renderers/.libs/libMgRenderers.so /usr/lib/gcc/i586-suse-linux/4.1.2/libstdc++.so ../../../Common/Security/libMgSecurity.a -Wl,--rpath -Wl,/usr/local/mapguideopensource/lib -Wl,--rpath -Wl,/usr/local/fdo-3.3.0/lib -Wl,--rpath -Wl,/usr/local/mapguideopensource/server/lib -Wl,--rpath -Wl,/usr/lib/gcc/i586-suse-linux/4.1.2 -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Oem/dbxml-2.3.10/install/lib
-Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwf -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfemap -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Common/CoordinateSystem/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Common/MdfModel/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Common/MdfParser/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Common/Stylization/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Common/Renderers/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Common/Foundation/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Common/Geometry/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Common/PlatformBase/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Common/MapGuideCommon/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Common/Base/.libs -Wl,--rpath
-Wl,/usr/src/mapguide-2.0.1/Server/src/Common/Cache/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Common/Manager/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Common/Thread/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Services/Drawing/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Services/Feature/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Services/Kml/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Services/Mapping/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Services/Rendering/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Services/Resource/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Services/ServerAdmin/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Services/Site/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/Services/Tile/.libs -Wl,--rpath -Wl,/usr/src/mapguide-2.0.1/Server/src/UnitTesting/.libs
/usr/lib/gcc/i586-suse-linux/4.1.2/../../../../i586-suse-linux/bin/ld: warning: libxerces-c.so.27, needed by /usr/src/mapguide-2.0.1/Server/src/Services/Drawing/.libs/libMgServerDrawingService.so, may conflict with libxerces-c.so.25
/usr/src/mapguide-2.0.1/Common/Renderers/.libs/libMgRenderers.so: undefined reference to `gdFontCacheShutdown'
/usr/src/mapguide-2.0.1/Common/Renderers/.libs/libMgRenderers.so: undefined reference to `gdFontCacheSetup'
collect2: ld returned 1 exit status
make[3]: *** [mgserver] Error 1
make[3]: Leaving directory `/usr/src/mapguide-2.0.1/Server/src/Core'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/usr/src/mapguide-2.0.1/Server/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/mapguide-2.0.1/Server'
make: *** [all-recursive] Error 1
suse-10:/usr/src/mapguide-2.0.1 #
I have installed thd FDO 3.3.1 succesfully.
Thanx a lot.
Dorin
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080701/29af787d/attachment.html
