[mapguide-users] MapGuide OS WMS server
Gwenael Bachelot gwenael.bachelot at eur.autodesk.com
Thu Jul 3 17:30:13 EDT 2008
Hi Danas,
I am not sure it is what you are searching for, but I wrote on my blog two posts on how to publish WMS with MapGuide (using Autodesk MapGuide Studio).
It's in french, but with Google translation (on the left), and screenshots, I assume it can be useful.
You will find :
- publish WGS 84 WMS service : http://geospatialfrance.typepad.com/geospatialfrance/2008/06/publier-des-don.html
- publish with other coordsys : http://geospatialfrance.typepad.com/geospatialfrance/2008/06/publier-des-d-1.html
Cordialement,
Gwenael
Gwenael Bachelot - Mailto:gwenael.bachelot at autodesk.com
      http://blogs.autodesk.com/geospatialfrance
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Danas Augutis
Sent: jeudi 3 juillet 2008 15:21
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MapGuide OS WMS server
I'm not used to mapguide studio, I found 'is published check box, but was
unable to save layer after checking it (save was not active).
Is it somewhere in XML files of layers? I didn't found anything special in
sheboygan layers. Can you send my an example of publishing code, please?
Regards,
D.
On Thursday 03 July 2008 12:52:07 Zac Spitzer wrote:
> there's an is_published flag on the resource header for mapguide
> layers which when set
> exposes them via WMS... mapguide studio makes it easier
> if you look at the headers for the sheboygan layers you will see the
> setting in the xml
> z
> On Thu, Jul 3, 2008 at 7:48 PM, Dumas A <dumas65 at gmail.com> wrote:
> > I'm looking for info about wms services on MGOS. I'm interested to
> > provide some data via WMS.
> > I can see sheboygan example data in ArcCatalog using WMS, but none of my
> > Datasets are in server. Can you tell me where sheboygan example data for
> > WMS is configured? How to configure WMS server for Onw data?
> > Any help appritiated!
> > D.
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
