[mapguide-users] MapGuide OS WMS server
Kori Maleski
kori.maleski at gmail.com
Fri Jul 4 22:08:22 EDT 2008
Hi Maksim,
>From what I understand, vector data will overlay on Google fine via WMS
using WGS84 - EPSG 4326.
I have a number of layers configured this way and it works fine. But what
about raster imagery?
Google uses a modified Mercator for its tiles, and I need to overlay some
raster imagery layers. I need to reproject the raster to the appropriate
map projection for proper display.
If I format images in a modified Mercator, will MapGuide be able to
recognize the projection and will the WMS work?
I added the projections to the files in the nad and data directories for
both the server and web extensions, as well as modified the WMS axd file. I
can't get it to work. I get an invalid coordinate system error. Not sure
if I am doing something wrong or not configuring it correctly. Hoping
someone else has done this before.
Here is some info on the Google projections:
http://www.sharpgis.net/post/2007/07/26/The-Microsoft-Live-Maps-and-Google-M
aps-projection.aspx
http://www.iter.dk/post/2008/05/SphericalWeb-Mercator-EPSG-code-3785.aspx
Cheers,
Kori Maleski
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: July-03-08 11:55 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] MapGuide OS WMS server
Hi Kori,
Do you have any indicies how is EPSG:3785 different than standard WGS84?
I've been doing coordinate transformation from numerous other CRSes to WGS84
and everything worked fine with Google Earth/Maps. The most important part
of the process is, naturally, getting correct WGS84 transformation
parameters in first place. BTW, decimeter-precision range is out of question
due to GE/GM aerial imagery scale which is, if I recall correctly, 1:5000
(m) at best.
Regards,
Maksim Sestic
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kori Maleski
Sent: Friday, July 04, 2008 02:06
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MapGuide OS WMS server
Has anyone tried to publish to the new EPSG projection for Google - 3785 -
successfully?
Can the Proj4 library handle custom projections in this manner?
Cheers,
Kori Maleski
On Thu, Jul 3, 2008 at 2:30 PM, Gwenael Bachelot
<gwenael.bachelot at eur.autodesk.com> wrote:
Hi Danas,
I am not sure it is what you are searching for, but I wrote on my blog two
posts on how to publish WMS with MapGuide (using Autodesk MapGuide Studio).
It's in french, but with Google translation (on the left), and screenshots,
I assume it can be useful.
You will find :
- publish WGS 84 WMS service :
http://geospatialfrance.typepad.com/geospatialfrance/2008/06/publier-des-don
.html
- publish with other coordsys :
http://geospatialfrance.typepad.com/geospatialfrance/2008/06/publier-des-d-1
.html
Cordialement,
Gwenael
Gwenael Bachelot - Mailto:gwenael.bachelot at autodesk.com
http://blogs.autodesk.com/geospatialfrance
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Danas Augutis
Sent: jeudi 3 juillet 2008 15:21
I'm not used to mapguide studio, I found 'is published check box, but was
unable to save layer after checking it (save was not active).
Is it somewhere in XML files of layers? I didn't found anything special in
sheboygan layers. Can you send my an example of publishing code, please?
Regards,
D.
On Thursday 03 July 2008 12:52:07 Zac Spitzer wrote:
> there's an is_published flag on the resource header for mapguide
> layers which when set
> exposes them via WMS... mapguide studio makes it easier
> if you look at the headers for the sheboygan layers you will see the
> setting in the xml
> z
> On Thu, Jul 3, 2008 at 7:48 PM, Dumas A <dumas65 at gmail.com> wrote:
> > I'm looking for info about wms services on MGOS. I'm interested to
> > provide some data via WMS.
> > I can see sheboygan example data in ArcCatalog using WMS, but none of my
> > Datasets are in server. Can you tell me where sheboygan example data for
> > WMS is configured? How to configure WMS server for Onw data?
> > Any help appritiated!
> > D.
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080704/c9531cc7/attachment.html
