[mapguide-users] Create a Visual Studio 2008 Solution of dotnetviewersample
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Jul 8 03:09:58 EDT 2008
 From the looks of it, you have such a solution.
If you would like to share it, you can create an enhancment ticket:
http://trac.osgeo.org/mapguide/newticket
(You must be logged in with an OSGeo ID).
If you do not have a solution, you can create the request anyway.
On the ticket, you can attach your solution, so others may benefit, and
it may be included in future releases.
If you have the time, cleaning up the sample, and moving the server code
into "codebehind" files, you can attach them too.
Regards, Kenneth Skovhede, GEOGRAF A/S
stoff skrev:
> Hi,
> I downloaded the dotnetviewersample and want o make a Visual Studio 2008
> project of it. After copying the sample code to the VS-www directory and the
> MG-dlls to the bin directory, I opend the directory as Website. Trying to
> compile,  I came across the following problems ...
> 1) Type or Namespace JsonObject was not found => I took the proper namespace
> Jayrock.Json ... works!
> 2) File \query\property.aspx could not be found => not strange, because it
> is stored in the directory \query\classes\property.aspx ... but where is
> this path stored?... in a binary?  I have not found it in the code and moved
> the file in the directory above ... dirty but works ...
> 3) The path /utilityfunctions.aspx could not be assigned. ... found some
> wrong include paths, but can't eleminate this error ... any ideas?
> A downloadable Visual Studio website solution would be great ...  ;-)
> Has anyone experiences with the asp.net development server? I don't want to
> install IIS on my development machine ...
> Best regards ...
> stoff
