[mapguide-users] New Feature Source
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Jul 8 03:37:44 EDT 2008
I have not tried to create a feature source with webstudio,
but I have seen others report that it works.
I think you have to leave the files somewhere on the server
disk, and then reference them there.
The MGP packages are basically Zip files of your entire setup.
Even though you could create a featuresource that way, it would
be very cumbersome.
Currently you can only create/load MGP packages through the Site
Administrator.
There are two other applications that can replace/co-exist with WebStudio:
MapGuide Maestro: http://trac.osgeo.org/mapguide/wiki/maestro
Autodesk MapGuide Studio:
http://www.autodesk.es/adsk/servlet/index?siteID=123112&id=7176611
The first one is free, the second one is a trial but has full
documentation.
You might find it easier to create feature sources with one of those.
Regards, Kenneth Skovhede, GEOGRAF A/S
ramiroBot skrev:
> How do i create a new Feature Source? Seems there are some files missing, as
> i click Upload Data into a new Feature Source:
> concept_featuresource.html
> concept_layer.html
> concept_map.html
> These files seem to be from the help system, that doesnt come with the
> distribution, if i could create a new Feature Source without them.
> I logged on webstudio trough http://localhost:8008/mapguide/webstudio, with
> Admnistrator/admin, and alredy added the map author role to Administrator
> (and some other users to test, and the problem persists).
> Im on Windows XP, with Mapguide and web extensoins on version 2.0.1.2716, on
> a java development environment. The sample example loads normally. My
> expectation is that through webstudio i can create a package like the
> Sheboygan.mgp, to load trough the jsp. Is that correct?
