[mapguide-users] Raster images in MGE 2009
Jason Birch
Jason.Birch at nanaimo.ca
Tue Jul 8 12:48:29 EDT 2008
Config.xml is stored in the MapGuide repository as resource data. In
PHP, it looks something like this:
$resourceService->SetResourceData($resourceID, "ConfigurationDocument" ,
"Stream", $dataByteSource->GetReader());
I've got a script that creates a config document and attaches it to a
Resource in the repository:
http://tinyurl.com/5fwc3v
You can also look at the code for the Maestro authoring tool, or watch
what it does using Fiddler2 as it creates these config files.
Jason
-----Original Message-----
Subject: RE: [mapguide-users] Raster images in MGE 2009
1. The second arg for the Get/SetResourceData(MgResourdeIdentifier,
string
dataName) methods, where does this value come from or what should this
be?
when I execute the method I receive a "Resource data was not found:
<dataName>". The exception is the same regardless of what the dataName
arg
value is. Obviously I am missing something here.
2. I can not find a config.xml anywhere on the file system. Before
clicking "Test Connection" and Save, or After testing the connection and
saving. Any suggestions?
thanks,
dave
