[mapguide-users] Get Coordinates
Dorin
did_1414 at yahoo.com
Thu Jul 10 06:20:30 EDT 2008
I forgot to say after the conversion you have got to introduce the necessary corrections depend on the map projection.
The point with (X,Y) is Cartesian projection.
----- Original Message ----
To: mapguide-users at lists.osgeo.org
Sent: Thursday, July 10, 2008 12:33:58 PM
Subject: Re: [mapguide-users] Get Coordinates
Hi all, I have solved using the suggestions of Dorin333...
I managed the DigitizePoint() function in the js, so when I click there is a
popup with the coordinates (meters), but now I have to convert it into
latlon. There is alredy a function that make this?
Thanks a lot to all
Kenneth Skovhede, GEOGRAF A/S wrote:
> It's a bit unclear what you want.
> If you want to get the coordinate when you click, Dorin is correct.
> The javascript function is called "DigitizePoint".
> If you want to display the coordinates as the mouse moves, you will have
> to
> study the file "ajaxmappane.templ" and figure out what function to hook
> into.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Dorin skrev:
>> Hi,
>> On the phpviewer sample (PHP code) you have a markup option, and you
>> can create on a click mouse on a map (get coordinate x,y) an point.You
>> can studying this samples in order to find a solution.
>> Dorin
>> From: gimbrogno <magnitudo9 at email.it>
>> Sent: Tuesday, July 8, 2008 6:28:46 PM
>> Hi I have the same problem... Have you solved? Can you or any other
>> people
>> help me to solve my problem?
>> Thanks a lot
>> Jhonn Jairo Vesga Cadena wrote:
>> > Hi, i have a map in autodesk studio 2007, and i need to solve this
>> issue:
>> > I need to create a point begins by click on the map, when i click the
>> > application launch a window where i get the X and Y coordinate, the
>> > problem its that, how can i get that coordinate??
>> > Some ideas??
>> > Thanks
>> > att:
>> > Móvil:
>> > Movistar: 316-524-4147
>> > _______________________________________________
>> > mapguide-users mailing list
>> > mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/Get-Coordinates-tp13951030p18341934.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com
>> <http://Nabble.com>.
View this message in context: http://www.nabble.com/Get-Coordinates-tp13951030p18379167.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080710/e3a02d52/attachment.html
