[mapguide-users] Error to log on to MGOS 2.0.1 using MapGuide Maestro
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jul 14 03:17:28 EDT 2008
What Zac meant was: What happens if you enter the url
"http://localhost/mapguide/mapagent/mapagent.fcgi" into the address
field in
your webbrowser?
Regards, Kenneth Skovhede, GEOGRAF A/S
Intengu Technologies skrev:
> It works fine in a browser and does not work when I use MapGuide
> Maestro r3235.msi
> 2008/7/14 Zac Spitzer <zac.spitzer at gmail.com
> <mailto:zac.spitzer at gmail.com>>:
>     what happens if you open the url in a browser?
>     z
>     On Mon, Jul 14, 2008 at 5:01 PM, Intengu Technologies
>     <sindile.bidla at gmail.com <mailto:sindile.bidla at gmail.com>> wrote:
>     > That is the url I am using:
>     > and the getting the error message.
>     > 2008/7/13 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk
>     <mailto:ks at geograf.dk>>:
>     >> Have you tried using the full URL?
>     >> It should work with the shorter form, though.
>     >> I am getting the following error message: Failed to log on
>     because: Failed
>     >> to connect, please check network connection and login
>     information. Extended
>     >> error info: Failed to connect, perhaps session is expired?
>     Extended error
>     >> info: The remote server returned an error: (404) Not Found
>     >> I am using MapGuide Maestro r3235.msi on MGOS 2.0.1 and MGOS
>     Web Studio
>     >> works fine.
>     >> Sindile Bidla
>     >> ________________________________
>     >> _______________________________________________
>     >> mapguide-users mailing list
>     >> mapguide-users at lists.osgeo.org
>     <mailto:mapguide-users at lists.osgeo.org>
>     >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>     > Sindile Bidla
>     Zac Spitzer -
>     http://zacster.blogspot.com (My Blog)
>     +61 405 847 168
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> Sindile Bidla
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080714/2ad392fb/attachment.html
