[mapguide-users] Error to log on to MGOS 2.0.1 using MapGuide Maestro
Intengu Technologies sindile.bidla at gmail.com
Mon Jul 14 04:08:21 EDT 2008
When I enter the url with the port number it works
"http://localhost:8008/mapguide/mapagent/mapagent.fcgi"<http://localhost/mapguide/mapagent/mapagent.fcgi>
Is there a way to resolve this
2008/7/14 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>:
>  What Zac meant was: What happens if you enter the url
> "http://localhost/mapguide/mapagent/mapagent.fcgi"<http://localhost/mapguide/mapagent/mapagent.fcgi>into the address field in
> your webbrowser?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Intengu Technologies skrev:
> It works fine in a browser and does not work when I use MapGuide Maestro
> r3235.msi
> 2008/7/14 Zac Spitzer <zac.spitzer at gmail.com>:
>> what happens if you open the url in a browser?
>> z
>> On Mon, Jul 14, 2008 at 5:01 PM, Intengu Technologies
>> <sindile.bidla at gmail.com> wrote:
>> > That is the url I am using:
>> > and the getting the error message.
>> > 2008/7/13 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>:
>> >> Have you tried using the full URL?
>> >> It should work with the shorter form, though.
>> >> I am getting the following error message: Failed to log on because:
>> Failed
>> >> to connect, please check network connection and login information.
>> Extended
>> >> error info: Failed to connect, perhaps session is expired? Extended
>> error
>> >> info: The remote server returned an error: (404) Not Found
>> >> I am using MapGuide Maestro r3235.msi on MGOS 2.0.1 and MGOS Web Studio
>> >> works fine.
>> >> Sindile Bidla
>> >> ________________________________
>> >> _______________________________________________
>> >> mapguide-users mailing list
>> >> mapguide-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> > Sindile Bidla
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
> Sindile Bidla
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
Sindile Bidla
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080714/84653628/attachment.html
