[mapguide-users] Raster Config XML File
Dave Brett dbrett at digitalglobe.com
Mon Jul 14 12:46:55 EDT 2008
I took this from a raster config file for the GDAL provider, it looks very
similar to the Autodesk providers config information.  It appears there is a
section missing from your image node (see bold text), hope this helps.
dave
<SchemaMapping xmlns="http://fdogrfp.osgeo.org/schemas"
provider="OSGeo.Gdal.3.3" name="default">
<complexType name="defaultType">
 <complexType name="RasterTypeType">
 <RasterDefinition name="images">
 <Location name="C:\temp\">
 <Feature name="633510537879531250.jpg">
 <Band name="RGB" number="1">
 <Image frame="1" name="633510537879531250.jpg">
 <Bounds>
  <MinX>-10000000</MinX>
  <MinY>-10000000</MinY>
  <MaxX>10000000</MaxX>
  <MaxY>10000000</MaxY>
  </Bounds>
  </Image>
  </Band>
  </Feature>
  </Location>
  </RasterDefinition>
  </complexType>
  </complexType>
  </SchemaMapping>
gom wrote:
> I am looking for some help on creating a raster config XML file.  I want
> to
> attach an ESRI .asc grid file to AutoCAD Map.  I have a config file for
> raster that I pinched from an AutoCAD Map code sample but I have not been
> able to modify it in such as way as seems to work.  I can attach the
> raster
> programatically but it complains about the "band" tag in the XML.  As this
> is not bitmap of any sort I guess I can see why but I can't seem  to find
> enough documentation to show me what to do.
> Does anyone have a sample config file for a raster grd or can you point me
> to some documentation resources that explain the contents.  I have found
> little bits and pieces but nothing complete enough to get the job done.
> Any
> help would be greatly appreciated.   I have included my XML in case it is
> helpful in answering
> Thanks
> <?xml version="1.0" encoding="UTF-8" ?>
> <file:///C:\Documents%20and%20Settings\mckgor01\Local%20Settings\Temp\tempSu
> rface.xml##> - <fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:fdo="http://fdo.osgeo.org/schemas"
> xmlns:fds="http://fdo.osgeo.org/schemas/fds">
> rface.xml##> - <gml:DerivedCRS gml:id="Default">
> rface.xml##> - <gml:metaDataProperty>
> rface.xml##> - <gml:GenericMetaData>
>   <fdo:XYTolerance>0.001000</fdo:XYTolerance>
>   <fdo:ZTolerance>0.001000</fdo:ZTolerance>
>   </gml:GenericMetaData>
>   </gml:metaDataProperty>
>   <gml:remarks>System generated default FDO Spatial Context</gml:remarks>
>   <gml:srsName>Default</gml:srsName>
> rface.xml##> - <gml:validArea>
> rface.xml##> - <gml:boundingBox>
>   <gml:pos>550000.000000 6500000.000000</gml:pos>
>   <gml:pos>552000.000000 6502000.000000</gml:pos>
>   </gml:boundingBox>
>   </gml:validArea>
>   <gml:baseCRS xlink:href="http://fdo.osgeo.org/crs#default_cartesian" />
>   <gml:definedByConversion
> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
>   <gml:derivedCRSType
> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
>   <gml:usesCS xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
>   </gml:DerivedCRS>
> rface.xml##> - <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
> targetNamespace="http://fdo.osgeo.org/schemas/feature/rasters"
> xmlns:rasters="http://fdo.osgeo.org/schemas/feature/rasters"
> elementFormDefault="qualified" attributeFormDefault="unqualified">
> rface.xml##> - <xs:element name="tempSurface"
> type="rasters:tempSurfaceType"
> abstract="false" substitutionGroup="gml:_Feature">
> rface.xml##> - <xs:key name="tempSurfaceKey">
>   <xs:selector xpath=".//tempSurface" />
>   <xs:field xpath="Id" />
>   </xs:key>
>   </xs:element>
> rface.xml##> - <xs:complexType name="tempSurfaceType" abstract="false"
> fdo:hasGeometry="false">
> rface.xml##> - <xs:complexContent>
> rface.xml##> - <xs:extension base="gml:AbstractFeatureType">
> rface.xml##> - <xs:sequence>
> rface.xml##> - <xs:element name="Id">
> rface.xml##> - <xs:annotation>
>   <xs:documentation />
>   </xs:annotation>
> rface.xml##> - <xs:simpleType>
> rface.xml##> - <xs:restriction base="xs:string">
>   <xs:maxLength value="256" />
>   </xs:restriction>
>   </xs:simpleType>
>   </xs:element>
> rface.xml##> - <xs:element name="Image" type="fdo:RasterPropertyType"
> fdo:defaultImageXSize="200" fdo:defaultImageYSize="200"
> fdo:srsName="Default">
> rface.xml##> - <xs:appinfo source="http://fdo.osgeo.org/schemas">
>   <fdo:DefaultDataModel dataModelType="Unknown" dataType="Unknown"
> organization="Row" bitsPerPixel="32" tileSizeX="128" tileSizeY="128" />
>   </xs:appinfo>
>   </xs:annotation>
>   </xs:element>
>   </xs:sequence>
>   </xs:extension>
>   </xs:complexContent>
>   </xs:complexType>
>   </xs:schema>
> rface.xml##> - <SchemaMapping provider="Autodesk.Raster.3.2"
> name="rasters"
> xmlns="http://www.autodesk.com/isd/fdo/RasterFileProvider">
> rface.xml##> - <complexType name="tempSurfaceType">
> rface.xml##> - <RasterDefinition name="rasters">
> rface.xml##> - <Location name="">
> rface.xml##> - <Feature name="tempSurface.asc">
> rface.xml##> - <Band name="RGB" number="1">
>   <Image name="tempSurface.asc" frame="1" />
>   </Band>
>   </Feature>
>   </Location>
>   </RasterDefinition>
>   </complexType>
>   </SchemaMapping>
>   </fdo:DataStore>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Raster-Config-XML-File-tp18445587p18447942.html
