[ZS1] RE: [ZS1] RE: [mapguide-users] mapguide intergration
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Jul 16 08:52:35 EDT 2008
What is the name of the feature class?
It is listed as "Schema" in Maestro, I can't remember what it is called
in Studio, but likely the same.
Better yet, could you email me the layerdefinition privately?
Right click the layer and select "Save Xml as...".
Regards, Kenneth Skovhede, GEOGRAF A/S
Andre Schoonbee skrev:
> Using Maestro 1.0.8
> MapGuide Server (Version 2.0.0.2716)
> MapGuide Site Administrator (Version 2.0.0.2716)
> Well, I used only Maestro in defining the dataconnection (fdo to shp)
> connecting to a shapefile, the layer, map and layout. I did not add
> any url or tooltip links, just the basic styling to show towns as a
> circle. Still noting displays. I have the following error:
> <2008-07-16T13:39:10> Administrator
> Error: The specified class was not found.
> StackTrace:
> - MgRenderingServiceHandler.ProcessOperation line 83 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
> - MgOpQueryFeatures.Execute line 125 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
> - MgServerRenderingService.QueryFeatures line 652 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\ServerRenderingService.cpp
> - MgServerRenderingService.RenderForSelection line 1299 file
> - MgServerDescribeSchema.GetClassDefinition line 1440 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
> <2008-07-16T13:39:14> Administrator
> Error: Failed to stylize layer: tawns
> StackTrace:
> - MgMappingUtil.StylizeLayers line 775 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\mapping\MappingUtil.cpp
> <2008-07-16T13:39:15> Administrator
> StackTrace:
> Regards
> Andre
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* Wednesday, July 16, 2008 1:11 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [ZS1] RE: [mapguide-users] mapguide intergration
> Usually "class" means feature class, aka tablename.
> I did see some reports that Maestro and Studio had different ways of
> encoding the class names.
> What happens if you re-open the layer in Studio?
> Have you tried different column names?
> Does it still work if you do not use concat, eg just:
> 'test string'
> Hi Kenneth
> Well, I upgraded to Maestro 1.0.8. I then deleted all files previously
> created and started fresh. I used a shapefile. By using Studio 2009, I
> managed to define the layer, map and layout and tested the web page 100%.
> I then used Maestro to add the CONCAT URL statement, saved the layer
> and refreshed the webpage. The result was no poins dispayed.
> The fowling is in my error log file:
> <2008-07-16T09:23:21> Administrator
> StackTrace:
> <2008-07-16T09:23:26> Administrator
> Error: Failed to stylize layer: Towns
> StackTrace:
> <2008-07-16T09:23:30> Administrator
> StackTrace:
> Regards
> Andre
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> *Sent:* Tuesday, July 15, 2008 3:04 PM
> *Subject:* Re: [mapguide-users] mapguide intergration
> There was an error in Maestro 1.0.7 regarding points symbols in a layer.
> You can upgrade to 1.0.8 and it should work:
> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
> If the layer does not render with the updated singly quoted strings,
> there should be an entry in the server log file:
> C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
> Hi List
> Man I am frustrated!
> I added a shapefile using Autodesk Sudio 2009, and it display correctly.
> I then tried to use Maestro and/or WebStudio to add the Concat
> statement, but the result is that I end up with a map not displaying
> the points.
> I also loaded the points shapefile into postgis. I use Quantum to view
> the table and it display 100%. (Postgres 8.2) I then created a db
> connection from Maestro (1.0.7.40948) and tried to add a layer using
> the data connection defined. I have specified the Custom Editor and
> Generic editor settings to make sure even the schema is defined. I
> also tested the connection and no errors were displayed. I did add a
> layer that connects to the database and saved it. The minute I want to
> add the layer style (point) I keep on getting an error:
> /An Error occurred saving: The remote server returned an error: (559)
> MgDbXmlException.:/
> /An exception occurred in DB XML component./
> /Error: XML Indexer: Parse error in document at line, 25 char 22,
> Parse message: Element ‘ForegrountColor’ is not valid to content model:/
> /‘((FillPattern, ForegroundColor,BackgroundColor).ExtendedData1)’/
> /Exception occurred in method
> MgResourceDefinitionManager.UpdateDocument at line 601 in file/
> /D:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceDefinitionManager.ccp/
> Any help would be appreciated!
> Regards
> Andre
> *Sent:* Friday, July 11, 2008 11:48 AM
> Oh, and besides, I think you should use single quotes for strings?
> Concat ( 'http://localhost/maps/searching.php?fid=' , FeatId )
> Hi
> First, thanks for the feedback
> The problem is that using I use Autodesk Mapguide sutio 2009 Trail, and when
> entering the conact string - I get an error :
> Error: The expression has an undefined property
> '"http://localhost/maps/searching.php?fid=" <http://localhost/maps/searching.php?fid=>'. Click here to move the cursor
> to the error(12)#12
> Regards
> Andre
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org <mailto:mapguide-users-bounces at lists.osgeo.org>
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
> Sent: Thursday, July 10, 2008 8:14 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] mapguide intergration
> I think you should have:
> Concat ( "http://localhost/maps/searching.php?fid=" <http://localhost/maps/searching.php?fid=> , FeatId )
> (I assume your key column is actually named "FeatId")
>> Hi Jason
>> I have no idea on how to do this.
>> What I want is to pass the Feature ID (fid) to my localhost map web server
>> running as http://localhost/maps.
>> If I execute http://localhost/maps/searchng.php?fid=1, I get the correct
>> information on my screen. The web screen is html and php.
>> So I need to be able to pass the fid to my connection sting.
>> I have tried this but seems not to be working.
>> Concat ( "http://localhost/maps/searching.php?" <http://localhost/maps/searching.php?> , FeatId )
>> Regards
>> Andre
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
>> Sent: Tuesday, June 17, 2008 5:38 PM
>> Subject: RE: [mapguide-users] mapguide intergration
>> Andre,
>> I think you can do this by concatenating some constant text (the URL)
>> with an attribute value (the town name) in the link.
>> I have no idea how this will work with your framed setup though. It may
>> be better to have the link trigger a javascript function (I haven't
>> experimented with this) that does something in the parent frame.
>> Jason
>> From: Andre Schoonbee
>> Subject: [mapguide-users] mapguide intergration
>> I have a php driven web based system and also a towns map running on
>> MGOS.
>> By using the "URL link", on Maestro or on Autodesk Mapguide studio, I
>> want
>> to pass the town name from the map to the other web system. The map will
>> be
>> running within an iframe in the system.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> __________ Information from ESET Smart Security, version of virus
> signature
>> database 3194 (20080617) __________
>> The message was checked by ESET Smart Security.
>> http://www.eset.com
>> No virus found in this incoming message.
>> Checked by AVG.
>> Version: 7.5.524 / Virus Database: 270.3.0/1505 - Release Date: 16-Jun-08
>> 7:20 AM
>> No virus found in this outgoing message.
>> Checked by AVG.
>> Version: 7.5.524 / Virus Database: 270.4.7 - Release Date: 08-Jul-08 12:00
>> AM
> __________ Information from ESET Smart Security, version of virus signature
> database 3259 (20080710) __________
> http://www.eset.com
> Checked by AVG.
> AM
> Checked by AVG.
> Version: 7.5.524 / Virus Database: 270.4.7/1545 - Release Date: 10-Jul-08
> 6:43 PM
> signature database 3262 (20080711) __________
> http://www.eset.com
> Checked by AVG.
> 10-Jul-08 6:43 PM
> Checked by AVG.
> Version: 7.5.524 / Virus Database: 270.4.11/1553 - Release Date:
> 15-Jul-08 5:48 AM
> signature database 3269 (20080715) __________
> http://www.eset.com
> Checked by AVG.
> 15-Jul-08 5:48 AM
> Checked by AVG.
> 15-Jul-08 5:48 AM
> Checked by AVG.
> Version: 7.5.524 / Virus Database: 270.4.11/1554 - Release Date:
> 15-Jul-08 6:03 PM
> Checked by AVG.
> 15-Jul-08 6:03 PM
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080716/265ac1d3/attachment.html
