[mapguide-users] Upgrade to 2.0 Question
Steve Dang
steve.dang at autodesk.com
Thu Jul 17 14:04:48 EDT 2008
If your repositories were originally/freshly created by MG Server 2.0, then you do not need to run the UpgradeRepositories.bat and SetupRepositoryIndices.bat files at all.
However, there is no harm if you run these batch files anyway. These files are only required to be run during the upgrade (http://trac.osgeo.org/mapguide/wiki/1.2to2.0MigrationInstructions).
Steve.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Warren Medermach (External)
Sent: Thursday, July 17, 2008 10:42 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Upgrade to 2.0 Question
I've also been told (sorry, can't remember where or who) that if you
load a package from a previous release you should also run the
UpgradeRepositories.bat & SetupRepositoryIndices.bat batch files located
in the ..\Server\RepositoryAdmin folder.
Can somebody verify that this is a required step?
Warren M
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Thursday, July 17, 2008 10:35 AM
To: 'MapGuide Users Mail List'
I've personally found that the easiest way to upgrade is to first export
a
package of your ENTIRE 1.2 repository and then load that package into
your
2.0 site. You may want to re-install 1.2 somewhere, export your
repository,
then re-install 2.0 so that it's initially working and then load the
package.
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George
McLean
Sent: Thursday, July 17, 2008 9:20 AM
Subject: [mapguide-users] Upgrade to 2.0 Question
Hello,
I have successfully upgraded a windows server 2003 system following the
migration instructions.
In attempting to upgrade an XP SP2 system I made a mistake and did not
uninstall V1.2 before installing v2.0. I realized my mistake and
uninstalled v1.2 and then v2.0. I then re-installed v2.0 but have not
had much success.
The Mapguide service will not start in a reboot of the system. I see
errors in the error log indicating the repository version is incorrect
(V5 instead of V6). I have tried running the UpgradeRepositories.bat but
get errors upgrading the Site repository and Library repository stating
the "Program version 4.5 doesn't match environment version ....". I have
tried this with my 1.2 repositories and also with the repositories that
are installed right from v2.0.
I am guessing I have some registry setting or some environment variable
that was not cleared out by the removal of v1.2 but I have not found
anything.
Any suggestions on how to clean this up and just install 2.o from
scratch? I have my repositories from 1.2 backed up elsewhere.
Thanks
George McLean
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
