[mapguide-users] Mr Sid problems in MGOS 2.0
Jason Birch
Jason.Birch at nanaimo.ca
Thu Jul 17 19:18:04 EDT 2008
Hi George,
The instructions for 2.0 (and 2.0.1) are somewhat different than for
previous versions:
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#FDO3.3.0MapGuide2.0.0
You should not install gdal1.4.dll. You should only need to install the
three MrSID plugin files.
However... If you're seeing the files opening, it may be that you're
running into the problem with the coordinate system being set to a value
other than that of the map, and may need to set a CS override in the
data connection for the raster data.
Are there any exceptions in your mapguide error log?
Another possibility is that you're not in the right place when
previewing the data. I think that the raster provider in 1.2 may have
done a better job of reporting the extents of MrSID files. This is just
a gut feeling though; I haven't taken the time to test/document the
problem.
Jason
-----Original Message-----
Subject: [mapguide-users] Mr Sid problems in MGOS 2.0
Hello, I have one last issue (I hope) upgrading to 2.0 from 1.2. I can
not get my Mr Sid files to render in MG 2.0.
I have installed the gdal1.4 dll and can see the files opening when
running mgserver from a command window so I think I have the file paths
correct. These sid files worked in MG 1.2.
I see a lot of discussion regarding sid files and connection handles,
memory issues etc. but I do not think I am even getting that far!
