[mapguide-users] MAESTRO and FDO
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jul 18 06:42:45 EDT 2008
Ok, I can reproduce now.
It is an error in Maestro, I have logged this ticket for it:
http://trac.osgeo.org/mapguide/ticket/636
When you enable "lines", you must also add a line display style.
To do this, click the green "+" sign.
Then double click the "line style" box, and set up a color and line width.
You can now save the layer.
I realize that this is not as obvious as I thought.
I have filed an enhancement ticket for it:
http://trac.osgeo.org/mapguide/ticket/637
Regards, Kenneth Skovhede, GEOGRAF A/S
Edmondo skrev:
> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> Edmondo skrev:
>>> Dear All,
>>> Trying to add feature to display (area for example) MAESTRO returns an
>>> error,
>>> But it seems the shape is correct: I opened the file in ARCGIS and it
>>> contains areas and other metadata.
>> What are the exact steps you took to produce the error?
>> And what is the exact error message?
>> Does the Shape filename have a space or other non-standard character?
> 1) DATACONNECTION with FDO SHP PROVIDER
>   1.1 - In Custom Editor - Unmanaged (file on the server) => files's path
> (%MG_DATA_PATH_ALIAS[quadro]%qu_10u33.shp);
>   1.2 - Save source in the data source folder;
> 2) LAYER CREATION
>   2.1 - FEATURE RESOURCE to a shape's source;
>   2.2 - set new layer style: I checked "displays lines"
>   2.3 - Save => It returns msg error attached:
>   2.3 - I checked "displays areas"
>   2.4 - Save => It returns another msg error: "an error occured while
> saving: Object referenced set
>       to  an instance of an object"
> http://www.nabble.com/file/p18526140/error%2Bareas.jpg
> http://www.nabble.com/file/p18526140/lines.jpg
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080718/762e3636/attachment.html
