Re[mapguide-users] dlining error
Marius_360 marius at openspatial.co.za
Fri Jul 18 09:43:07 EDT 2008
Great, I got it to work with:
var featureService: MgFeatureService =
MgFeatureService(siteConnection.CreateService(MgServiceType.FeatureService));
Thanks
Now for my next problem…
What does the LayerDefinitionFactory do? I’ve got the
layerdefinitionfactory.php file included in my aspx page, but on the
var factory = new LayerDefinitionFactory();
var lineRule = factory.CreateLineRule(ruleLegendLabel, filter, color); I
get:
Variable 'LayerDefinitionFactory' has not been declared
Kenneth Skovhede, GEOGRAF A/S wrote:
> There is a class map together with the documentation:
> http://mapguide.osgeo.org/2.0/documentation.html
> This can be found in the Web API documentation:
> http://mapguide.osgeo.org/files/mapguide/docs/webapi/index.htm
> The specific class is here:
> http://mapguide.osgeo.org/files/mapguide/docs/webapi/d5/d10/class_mg_feature_service.htm
> And the "CreateService" is here:
> http://mapguide.osgeo.org/files/mapguide/docs/webapi/df/d57/class_mg_site_connection.htm
> As for dll, that depends... the class you are seeing is in
> MapGuideDotNetApi.dll, but it is actually a wrapper
> for the other dll files in that folder.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Marius_360 skrev:
>> Where does the OSGeo.MapGuide.MgService come from, in other words, in
>> which
>> dll in the bin folder?
>>> So you are using JScript .Net?
>>> In that case you might have to typecast it:
>>> var featureService =
>>> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
>>> Not completely familiar with JScript.Net, but the error seems to
>>> indicate that the object (featureService) is of type MgService.
>>> MgService is a base class, and also the signature return type for
>>> CreateService.
>>> The actual type of the object returned is MgFeatureService.
>>> Marius_360 skrev:
>>>> This is exactly how I had it from the beginning, but it gives me
>>>> “Objects
>>>> of
>>>> type 'OSGeo.MapGuide.MgService' do not have such a
>>>> member” error
>>>> Carl Jokl wrote:
>>>>> I will assume this must be JScript .Net because what you are doing
>>>>> could
>>>>> not work at all otherwise but I see the problem in the code:
>>>>> var featureService = new MgFeatureService(); //You explicity create a
>>>>> new
>>>>> feature service. This is wrong
>>>>> //This method call retrieves the feature service from the site
>>>>> connection
>>>>> but you are not storing the //returned value
>>>>> //This will not work because you explicity created this feature
>>>>> service
>>>>> instead of getting it from the feature ///service
>>>>> featureService.CreateFeatureSource(resourceIdentifier, sdfParams)
>>>>> I am not completely familiar with JScript .Net but I would think that
>>>>> this
>>>>> should be
>>>>> //Get the feature service from the site connection, don't create it
>>>>> explicity.
>>>>> //Assuming you correctly created the resource identifier and the sdf
>>>>> params elsewhere this should work
>>>>> if (featureService) //Checking the returned feature service was not
>>>>> null
>>>>> just in case.
>>>>> sdfParams);
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Redlining-error-tp18524267p18529564.html
