[mapguide-users] MapGuide OS WMS server
Danas Augutis
dumas65 at gmail.com
Sat Jul 19 07:10:01 EDT 2008
Thanks for links Gwenael, but I still don't understand.
I was doing everything according our guides, but unfortunately i can not get
layer properties in MapGuide Maestro. Its inactive.
Is there any other way to set up WMS?
On Friday 04 July 2008 00:30:13 Gwenael Bachelot wrote:
> Hi Danas,
> I am not sure it is what you are searching for, but I wrote on my blog two
> posts on how to publish WMS with MapGuide (using Autodesk MapGuide Studio).
> It's in french, but with Google translation (on the left), and screenshots,
> I assume it can be useful. You will find :
> - publish WGS 84 WMS service :
> http://geospatialfrance.typepad.com/geospatialfrance/2008/06/publier-des-do
>n.html - publish with other coordsys :
> http://geospatialfrance.typepad.com/geospatialfrance/2008/06/publier-des-d-
>1.html
> Cordialement,
> Gwenael
> Gwenael Bachelot - Mailto:gwenael.bachelot at autodesk.com
> http://blogs.autodesk.com/geospatialfrance
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Danas Augutis
> Sent: jeudi 3 juillet 2008 15:21
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] MapGuide OS WMS server
> I'm not used to mapguide studio, I found 'is published check box, but was
> unable to save layer after checking it (save was not active).
> Is it somewhere in XML files of layers? I didn't found anything special in
> sheboygan layers. Can you send my an example of publishing code, please?
> Regards,
> D.
> On Thursday 03 July 2008 12:52:07 Zac Spitzer wrote:
> > there's an is_published flag on the resource header for mapguide
> > layers which when set
> > exposes them via WMS... mapguide studio makes it easier
> > if you look at the headers for the sheboygan layers you will see the
> > setting in the xml
> > z
> > On Thu, Jul 3, 2008 at 7:48 PM, Dumas A <dumas65 at gmail.com> wrote:
> > > I'm looking for info about wms services on MGOS. I'm interested to
> > > provide some data via WMS.
> > > I can see sheboygan example data in ArcCatalog using WMS, but none of
> > > my Datasets are in server. Can you tell me where sheboygan example data
> > > for WMS is configured? How to configure WMS server for Onw data?
> > > Any help appritiated!
> > > D.
> > > _______________________________________________
> > > mapguide-users mailing list
> > > mapguide-users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapguide-users
