AW: [mapguide-users] 2.0.1 / IIS / .NET instability?
Hans Mörschell
moerschell at geo.co.at
Sun Jul 20 03:30:47 EDT 2008
Hallo,
below the vb program and the batch file we use, any suggestions for a better
solutions are really welcome
thanks,
Hans
batch file for restarting MGOS like this:
netsh interface set interface LAN1 disable
taskkill /F /FI "SERVICES eq MapGuideServer2.0"
net stop W3SVC
net stop pgsql-8.2
net stop MapGuideServer2.0
net start W3SVC
net start pgsql-8.2
net start MapGuideServer2.0
netsh interface set interface LAN1 enable
this batch file is started by a little vb program (vb.net 2008):
- create a form and put the webbrowser control on it:
Public Class frmMonitor
Dim LogFileName As String = Application.StartupPath &
"\LOG\monitorlog.txt"
Dim DocLoaded As Boolean
Private Sub frmMonitor_Load(ByVal sender As System.Object, ByVal e As
System.EventArgs) Handles MyBase.Load
Me.WindowState = FormWindowState.Minimized
If System.IO.File.Exists(LogFileName) = False Then
System.IO.File.CreateText(LogFileName)
End If
TimerMonitor.Interval = 30000
TimerMonitor.Start()
End Sub
Private Sub TimerMonitor_Tick(ByVal sender As System.Object, ByVal e As
System.EventArgs) Handles TimerMonitor.Tick
' Mapguide Test / IIS Test / PostgreSQL DB Test
MapGuide_IIS_DB_Test()
End Sub
Sub MapGuide_IIS_DB_Test()
Dim TestSeite As String = ""
Dim strPos1 As Integer = -1
Dim StartZeit As Date = Date.Now
Dim ZeitDiff As Long = 0
If WebBrowserTest.IsOffline = False Then
Try
DocLoaded = False
Dim u As New Uri("http://localhost/webmonitor/start.aspx")
DocLoaded = False
WebBrowserTest.Navigate(u)
While DocLoaded = False
Application.DoEvents()
ZeitDiff = DateDiff(DateInterval.Second, StartZeit,
Date.Now)
If ZeitDiff > 10 Then
WebBrowserTest.Stop()
WriteLog("IIS / MapGuide Server / DB neu gestartet")
ServerAppRestart()
Exit Sub
End If
End While
TestSeite = WebBrowserTest.DocumentText
strPos1 = -1
If Trim(TestSeite) = "" Then
strPos1 = -10
Else
strPos1 = InStr(TestSeite, "Seite erfolgreich geladen")
End If
Select strPos1
Case 0
ServerAppRestart()
Case Else
End Select
Catch ex As Exception
ServerAppRestart()
End Try
Else
ServerAppRestart()
End If
End Sub
Sub ServerAppRestart()
TimerMonitor.Stop()
System.Diagnostics.Process.Start(Application.StartupPath &
"\mgosiisdbrestart.bat")
End Sub
Private Sub btnEnde_Click(ByVal sender As System.Object, ByVal e As
System.EventArgs) Handles btnEnde.Click
End
End Sub
Sub WriteLog(ByVal LogText As String)
If System.IO.File.Exists(LogFileName) = True Then
Dim strgDate As String = Date.Now.ToString
strgDate = strgDate & " "
Dim LogWriter As New System.IO.StreamWriter(LogFileName, True)
LogWriter.Write(strgDate & LogText & vbCrLf)
LogWriter.Close()
LogWriter.Dispose()
End If
End Sub
Private Sub WebBrowserTest_DocumentCompleted(ByVal sender As
System.Windows.Forms.WebBrowserDocumentCompletedEventArgs) Handles
WebBrowserTest.DocumentCompleted
DocLoaded = True
End Sub
End Class
_____
Von: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Andy Morsell
Gesendet: Samstag, 19. Juli 2008 17:48
An: 'MapGuide Users Mail List'
Betreff: RE: [mapguide-users] 2.0.1 / IIS / .NET instability?
Glad Im not the only one experiencing these problems
. Any chance that your
VB monitoring program can be made available to the group?
Thanks,
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
G.E.O.-Consulting / Hans Mörschell
Sent: Saturday, July 19, 2008 4:33 AM
To: 'MapGuide Users Mail List'
Subject: AW: [mapguide-users] 2.0.1 / IIS / .NET instability?
Hello,
we are using MGOS 2.0.1 / IIS7 / .NET whith an asp solution and the ajax
viewer. We have similar errors when using raster images (GDAL , MrSID and
Tiff mages), I think these problems where already discussed a little time
ago, but as far as I have seen there are no solution yet ???
At the moment we use a little monitoring program written in VB to check
every 30 seconds if mgserver is responding using a simple test layout.
Unfortunately restart of mgserver results in loss of session data so this is
not a perfect solution. I would be very interested in some other ideas how
to restart mgserver without loosing all user data, are there any suggestions
Thanks,
Hans Mörschell
_____
Gesendet: Freitag, 18. Juli 2008 19:32
Betreff: [mapguide-users] 2.0.1 / IIS / .NET instability?
Hi All,
I migrated my public demo server to 2.0.1 a few weeks ago. Since then, I
have found MapGuide to be much more unstable than it had been previously.
The service completely locks up (although appears started to Windows) and
cannot be restarted using normal methods and PSKill is the only solution to
restarting it. When looking at the server, I usually see an unhandled
exception error dialog with mgserver.exe the faulting module. The one
thing that is different now is that were using a Fusion layout instead of a
standard layout for a site that is regularly accessed. The Windows event
logs dont yield many clues, but the MGOS error.log has many of these
entries:
<2008-07-17T00:06:08> Fusion Viewer xxx.127.xxx.41 Anonymous
Error: Invalid argument(s):
The value cannot be less than or equal to zero.
StackTrace:
- MgRenderingServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src
\services\rendering\RenderingServiceHandler.cpp
- MgOpQueryFeatures.Execute line 125 file
\services\rendering\OpQueryFeatures.cpp
- MgServerRenderingService.QueryFeatures line 652 file
\services\rendering\ServerRenderingService.cpp
- MgServerRenderingService.RenderForSelection line 1041 file
\services\rendering\ServerRenderingService.cpp Invalid argument(s):
I know some folks were working on something to determine if the mgserver
service had locked up and, if so, restart it. Was anybody successful in
making something like this work? Its not fun to hit your map site only to
find it not working.
Thanks,
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080720/ab469bce/attachment.html
